Caster of GWaggy 44 for SOA Conversion?? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-21-2001, 10:55 PM Thread Starter
jamgood96's Avatar
Okay, I've been wondering. Am I going to have to rotate the knuckles on my front D44 to get the caster right for my SOA? Is this hard to do?
"James and the Giant Jeep"
1993 Wrangler 4.0/5spd, Herculined Interior
jamgood96 is offline
post #2 of (permalink) Old 01-22-2001, 09:09 AM
Re: Caster of GWaggy 44 for SOA Conversion??
If your just going SOA, and not using lift springs as well, your front driveshaft angle should be good enough that you dont need to rotate the pinion. You will need a longer front driveshaft (doubly so if you go SRS as well) but nothing more.
Otherwise- there are quite a few good write-ups on doing this in member's personal websites. Maybe you can find the info from one of the 'sites on JoeyCJ5's webpage.
'Gator Chaser
Sycho15 is offline
post #3 of (permalink) Old 01-22-2001, 12:32 PM
jeepgod's Avatar
well i used a wagoneer d44 from a 78.. it came with about +6 degrees of caster.. so what i did was to set it all up.. do not weld the spring perches on.. then i rotated the axle to kinda find a compromise between the pinion angle and the caster angle.. i now have +1 degrees of caster.. and a good pinion angle on it.. then welded the perches on.. you want atleast 0 degrees caster.. perferrably + caster.. with 6 degrees being about ideal.. but any positive caster will work... mine is fine driving on the road..
and yes.. you will need a longer front drive shaft.. unless you limit the flex of it.. i plan on getting a long travel front.. about 10" of spline..
http://www.jeepgod.net
jeepgod is offline
post #4 of (permalink) Old 01-22-2001, 03:53 PM Thread Starter
jamgood96's Avatar
Okay, can I get away with keeping my stock front driveshaft for a while before getting a longer one? You think I'll need to put lift springs on it too? I want to run 35" tires. Not any bigger. If I do anything, I replace the spring packs with something stronger(no sagging). Will that screw things up?
post #5 of (permalink) Old 01-22-2001, 04:31 PM
Going spring over will give you about 5.5" of lift using the stock springs. That should be enough for 35's. You WILL need a new front driveshaft. No ifs, ands, or buts about it. With that much lift it won't stretch enough to connect both ends. Plus with spring-over you will have much more wheel travel than stock meaning a longer slip-yoke.
'75 CJ5,258 w/Howell EFI,T18a,4.27's,33's,On-board air,Warn 8274
post #6 of (permalink) Old 01-22-2001, 04:40 PM Thread Starter
jamgood96's Avatar
Okay, so I need a front driveshaft, but a regular one or CV? Also, if I do a SRS later, will I need another driveshaft? And do I just put the spring pads on the opposite side of the tube, or rotate the pinion up a bit?
post #7 of (permalink) Old 01-22-2001, 05:44 PM
elusive's Avatar
thats just it jamgood.. as you rotate the pinion up, the caster gets more negative. you should be able to find a happy median like jeepgod.. remember to keep the caster positive.. even if it means a bit of angle on the front shaft.. it doesnt turn unless off road anyway, so a little angle will be fine. you might get lucky and be able to use your stock driveshaft.. i know a couple folks that did.. mine fits, but i think the length of the dana 60 helps me
~~Elusive~~
[img]/wwwthreads_images/icons/tongue.gif[/img]tj-7..tellico tested, uwharrie [img]/wwwthreads_images/icons/tongue.gif[/img]safaried..1 ton drivetrain[img]/wwwthreads_images/icons/tongue.gif[/img]..see it at http://www.jeepgod.net
oh yeah, and a 2000 tj,lift..etc
elusive is offline
