CJ5 flexes like a crowbar - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-21-2001, 10:59 AM
Here's my problem. I own a 1975 CJ5. It is pretty well set up with a 350 V8, Dana 20 t-case, Dana 30/AMC 20, and 35" tires (4"lift), but it drives like a basketball and flexes like a crowbar. I want to do a SOA using stock YJ springs to soften the ride and give me some articulation. My question(s) is/are: Since it is a '75 would I be miles ahead to just swap in the entire YJ suspension? I would need new hangers, perches, springs, longer upper shock mounts(longer shocks=more wheel travel..right?), and U-bolts/plates. I was wondering if I got all components listed above off of a YJ, then put the YJ spring hangers (I know they are wider than the frame) the same distance apart as the CJ hangers would that give me enough lift to run 35's? I am very clueless as you can see, so any help with any part of this conversion would be very helpful. E-mail me at [email protected] or just post it here! Thanks again.
Dont sweat the petty stuff and dont pet the sweaty stuff
post #2 of (permalink) Old 01-21-2001, 03:39 PM
Re: CJ5 flexes like a crowbar
Sounds like you've got it all figured out, but you would be smart to use only YJ rear springs. JC-Whitney makes some nice (so I've heard) HD 6-leaf military-wrapped replacement YJ springs that would be less likely to wear out so fast. They are $70 each I believe. Also, your steering will need some serious re-working to deal with that much lift (unless you just 'make it work' by making a Z-bar drag-link.)
'Gator Chaser
Sycho15 is offline
