-   -   U Joint Bolt socket?? (https://forums.off-road.com/jeep-short-wheelbase/53682-u-joint-bolt-socket.html)
**DONOTDELETE** 01-20-2001 12:18 PM
I was going to remove the U Joints in my front drive shaft this morning and find that is not a regular bolt head. I think it has a star head. Anyone know what tool is need to remove these? I looked in my haynes manual and it calls them U bolts.
Jeep info: 83 CJ 7 with auto trans, 300 transfer, 30 front axle.
Thanks,
Tom
**DONOTDELETE** 01-20-2001 01:35 PM
Re: U Joint Bolt socket??
The bolts on mine had regular nuts on 'em...do you have straps or u-bolts holding them on? If I had to make a guess, I'd say it probably takes a 12pt socket, instead of a 6pt.
Moneyless, Will weld for jeep accessories.
**DONOTDELETE** 01-20-2001 02:49 PM
I think I may have straps. This is my first time to mess with these so I am not sure. These bolt heads look like a torx bit with alot more sides. I may not be making any since here. I think I will go to Sears and look at what they have.
Thanks
Tom
ozarkjeep 01-20-2001 03:02 PM
yes its a really small torx socket.
I bought one at Autozone years ago. they are easy to strip ( the bolts no the socket)
so carefull! a toothbrush or wire brush works well to remove hte greasy mud from them to get a good grip.
you can buy replacement bolts at the dealorship, the heads on normal bolts are too large to fit .
probably better to just change to a strap type yoke, then spend the $2 each for eh "special" bolts though.
OzarkJeep
"If thats the way that you want it, well thats the way I want it more..."
**DONOTDELETE** 01-20-2001 04:32 PM
An 8mm 12 point socket will work. Must be 12 point though!
Common sense is genius dressed in working clothes.
http://www.austinjeeper.com
CJ money pit 01-20-2001 07:44 PM
Mine takes a twelve point 1/4" socket.
Max
82 CJ, some stuff stock, some stuff not
Have you hugged your Jeep today?
http://members.fortunecity.com/patrol14/index.html
