360 owners-HELP! - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-18-2001, 06:05 AM Thread Starter
360 owners-HELP!
I have around 500 miles on a rebuild. The Jeep has been sitting for a week due to a broken alternator bracket. Last night after installing the alternator, I started the Jeep. I had a slight knock and a violent spray of oil from the filter. I thought I might have bumped the filter when tightening the alternator, so I changed the oil and filter. SAME THING! It blew oil in a stream from the filter seal clear across to the other side of the Jeep. On the first filter, the seam was blown out. The second one had the rubber seal expelled.
HELP! I need ideas...
'86 CJ-7, 360, T-176, Dana 44 rear w/Truetrac, Dana 30, 4" Superlift, Slickrock hangers, Currie steering brace, JKS discos, 4:11s, Warn HS9500i on Durango bumpers.
BillR is offline
post #2 of (permalink) Old 01-18-2001, 06:15 AM
Re: 360 owners-HELP!
just a guess, the pressure relief spring and valve are stuck
its that long tube on teh side of the oil pump coverplate with a nut on teh end, carefully unscrew it, see if its stuck, clean/lube and reinstall.
thats my only guess, maybe itll point you towards the problem
OzarkJeep
"If thats the way that you want it, well thats the way I want it more..."
ozarkjeep is offline
post #3 of (permalink) Old 01-18-2001, 07:24 AM
I had the opposite problem on a 500 mile enigine this Summer - turned it on and there was NO pressure. My pressure relief valve was apparently stuck open - I'm thinking yours is stuck closed just like Ozarkjeep said...
Chuck Hadley
post #4 of (permalink) Old 01-18-2001, 10:02 AM
I think Ozark and Chuck are right on the mark with this one. I have had trouble from time to time getting the valve out of the cover plate on a couple of these. If this is the case and you can't get it out easily then remove the cover plate and it will be easier to get it out of there. If you have never installed a oil pump rebuild kit then just remember these couple of hints. Don't use RTV anywhere on the thing and use Vasaline to pack the drive gears and gasket so that they are held in place when reinstalling the cover when you fix the problem with the relief valve.
Hope this helps.
post #5 of (permalink) Old 01-18-2001, 01:41 PM Thread Starter
Thanks guys. I'll try that tonight!
Can you usually get the valve out without removing the cover?
BillR is offline
post #6 of (permalink) Old 01-18-2001, 01:54 PM
It just depends on how bad or what is making the valve stick. The last one that I had to do I actually had to take the cover off and push the valve out with a piece of wire because it got stuck so bad.
Have you replaced your oil pump parts in a while??? If not this would be a good time to do it.
post #7 of (permalink) Old 01-18-2001, 08:20 PM Thread Starter
That was it! The relief valve was stuck, and I had to remove the cover to get it out. The plunger was scored slightly. After re-assembly, there are no more leaks, but I still have the knock! It seems louder under the Jeep. Could this have happened when the relief valve seized? The engine has power and good oil pressure, but the knock sounds ominous. Someone please tell me it's nothing to worry about...:-)
BTW, when I had the oil pump cover off, there were two circular patterns on the cover where the gears had been riding on the cover. Is this normal?? It seems like it would grind the cover away, or at least put metal in the system.
BillR is offline
post #8 of (permalink) Old 01-18-2001, 08:30 PM
can you isolate the knock with the old broomstick to ear method ( watch the fan!)?
what weight oil are you running and whats the outside temp?
OzarkJeep
post #9 of (permalink) Old 01-18-2001, 08:36 PM Thread Starter
I tried that, and the knock appears to be coming from the bottom somewhere. It was the loudest when I had the screwdriver next to the drain plug on the oil pan. I can also hear it under the passanger-side valve cover, though not as loud as below.
Sorry! I'm running 10W-40 Pennzoil. My garage is around 40 degrees. (I had long-johns on!)
BillR is offline
post #10 of (permalink) Old 01-18-2001, 09:01 PM
man, I dont know, but if it doesnt go away ( quickly) I would probably do some inspecting before driving much.
I guess maybe the oil pickup tube could have gotten moved, although Im not sure thats even possible on the amc setup. hmm
did it not knock before this stuck releif valve?
If the pressure is good, and its running normal I guess its ok, but Im scared of knocks.. maybe someone with more AMC knowledge has better help for you here.
OzarkJeep
