hydrolic clutch on 360/t-18 combo? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-17-2001, 06:32 PM Thread Starter
One of my many winter projects is to fit a 360/t18 combo in a 92 wrangler. Is there any way to keep the original hydrolic clutch? Maybe by using the late cj's 4 cyl bell housing? is the bolt pattern is the same between the 360 and the amc 151 4 cyl? Wow, so many questions, so little jeeping time[img]/wwwthreads_images/icons/mad.gif[/img]
thanks for your time!
Ben
winchboy is offline
post #2 of (permalink) Old 01-17-2001, 07:03 PM
Re: hydrolic clutch on 360/t-18 combo?
just find a external hydraulic slave cylinder, fab a bracket to hold it on the bellhousing in a position so that it will actuate the clutch fork.
I plan to do the same, 360/t18 hyd clutch, ive procured a early 80s GM 4 banger master and slave cylinders just to mock up the brackets and firewall and such.
unless Im missing some unseen problem, it seems pretty strightforward.
OzarkJeep
"If thats the way that you want it, well thats the way I want it more..."
ozarkjeep is offline
post #3 of (permalink) Old 01-17-2001, 08:08 PM
I bet you can use the 92 clutch master. Get the mid 80's slave cyl, I know it will bolt to my 78 CJ bellhousing. The only problem I really see, is the hose, I bet the 92 has metric or qwick connect fittings. The mid 80's slave has SAE flare fittings, so it might be easier to adabt the mid 80's master also.
Tahnks, Ray
