Question about MORE leaf spring mounts... - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-09-2001, 05:15 PM Thread Starter
jamgood96's Avatar
Okay, I don't quite understand the concept of this product. Check out the site.
http://www.mountainoffroad.com/catalog/Mounting Hardware-Axle/Mounting Hardware.htm
These weld onto your axle tubes right? It says it's possible to move your axle foward, is this true? Why would you want to?
"James and the Giant Jeep"
1993 Wrangler 4.0/5spd, Herculined Interior
jamgood96 is offline
post #2 of (permalink) Old 01-14-2001, 03:03 AM
Re: Question about MORE leaf spring mounts...
when you do a reverse shackle set-up you need to move the front axle forward because the new movement of the axle is backward not forward. the kits you buy pre-fab'd are cut and welded to bring the axle forward so this kit from MORE icould be for the home-made job. I dont work for MORE but thats thats my poo cents.
post #3 of (permalink) Old 01-14-2001, 10:24 AM Thread Starter
jamgood96's Avatar
But this wasn't a shackle reversal deal. It was a leaf spring mount, like the type that goes on the axle. But since you brought up the shackle reversal setup, I heard that more hould be done to strengthen everything besides just moving the shackles. I heard that the added strain of a stiffer suspension should be corrected with rienforcments. This sucks. I don't remember where I read about this. Damn! It made some good points though.
post #4 of (permalink) Old 01-14-2001, 10:33 AM Thread Starter
jamgood96's Avatar
Okay, I found the info I was looking for. It's at the YJ FAQ page. You may or may not of read it...
1) Since the frame is lower at the rear spring eye, you will be
forced to lift the vehicle a fair amount - you may be happy with
this side effect, as it will allow you to have a lift and retain
the more desireable/efficient flat profile
2) The drop brackets you will need to mount the fixed end in
front will put a *lot* of stress on the very frontmost part of
the frame rails - laterally in particular. You will need to add
a lot of structure and crossbracing to keep the stiffness of the
chassis high enough to maintain the handling you have now *this
is one area I've seen lacking in any 'kits' that are out there -
they just don't do the engineering calcs to check for frame
integrity!
3) You will be using your front prop. slip yoke more - this
*shouldn't* be a big problem, unless you're running tons of lift
and the prop is at a big angle to the ground - just realize you
may wear it out and need a whole new drive shaft!
4) If you run big lift springs with lots of arc to them, realize
that your tires now move up and *back* when you hit a
bump/compress the suspension - which means your big meats will
have more chance of hitting the fenders in the footwell area.
