YJ Charging Problem. I goofed. Please Help - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-07-2001, 03:18 PM
Hey Guys,
I was messing with my Jeep today trying to fab up a setup for a York on a 2.5L (old style with NO provision for factory AC) and i did something stupid.
I forgot to disconnect the battery and when i removed the alternator the red wire going to it hit the battery tray and made a spark and then a little smoke came from the spot that is circled in the pic on the link below.
<A HREF="http://ct-web.unh.edu/yankeetoys/kspeicher/ohoh.htm[url]
My volt meter is now reading 10-11 instead of the usual 14 or so. I am afraid to drive it cause i dont think its charging. I tried using a spare alternator i had and still had the same problem
any ideaS?
p.s. On a good note, i will have a complete York setup on my 2.5L soon. I figured the whole thing out except for a little bracket for the idler pulley. Anyone needs the drawings lemme know
thanks
[b]Boston Mangler
89 YJ With A Bunch Of Goodies
See It At:
[url]http://ct-web.unh.edu/yankeetoys/kspeicher/" target="_new">http://ct-web.unh.edu/yankeetoys/kspeicher/ohoh.htm[url]
any ideaS?
thanks
[b]Boston Mangler
See It At:
[url]http://ct-web.unh.edu/yankeetoys/kspeicher/</A>
post #2 of (permalink) Old 01-07-2001, 06:04 PM
Re: YJ Charging Problem. I goofed. Please Help
Where are you taking your reading at. That kind of voltage reading is typical of a battery with a cell shorted out. Have you tried a different battery.
Brad
ORC Land Use Section Editor
http://www.off-road.com/land
post #3 of (permalink) Old 01-07-2001, 11:54 PM
Just making the link work for ya....sorry I don't have any good ideas to offer you.
--Digger--
http://www.users.qwest.net/~ascanlon
post #4 of (permalink) Old 01-08-2001, 01:31 AM
I'm not sure about the YJ's but if you did that on a CJ you would burn out the fusible link that's in that big red wire. The fusible link is usually up near the starter solenoid. In your picture, is that the starter solenoid? I couldn't tell, the CJ ones are round are the YJ one's square?
If the fusible link is blown there should be battery voltage at the relay end of the wire and no voltage down at the alternator end of the wire.
post #5 of (permalink) Old 01-08-2001, 03:04 AM
Wrangler88
hey boston mangler send me some pic's r diagrams for the 2.5L, i'm trying to throw one no my 95 wrangler but haven't had the chance and time yet, any help well would help! thanks!
(\/)ikey
1988 Wrangler Laredo 4.2L w/5spd Manual
1995 Wrangler 2.5L w/ 5spd / 31"BFG AT's
post #6 of (permalink) Old 01-08-2001, 04:21 AM
The symptoms, and the way the problem occured fit a partially destroyed diode pack.
Safe Jeepin'
Larry
post #7 of (permalink) Old 01-08-2001, 05:52 AM
***** What is the diode pack? Is that what is in the picture? Is it also called something else?
thanks
[b]Boston Mangler
See It At:
post #8 of (permalink) Old 01-08-2001, 05:54 AM
***** Would i get voltage at the gauge? Wouldnt a blown fusible make me loose all power?
thanks
[b]Boston Mangler
See It At:
post #9 of (permalink) Old 01-08-2001, 06:02 AM
1. Take a look in your manual to see if the Alternator has an internal diode pack. I think it may. These usally are about 1" or "kinda square" and encapsulated in a ceramic material to help transfer heat to the alternator case. If it's internal... then you've got to open up the alternator and remove it and take it to NAPA or another Auto Parts Store. They should have a tester. If you knew the schematic for the pack you could test it at home with an Digital multimeter. Testing a diode is simple... put the tester on Ohms and check each diode for a ratio of 10:1 ohms when the leads are reversed.
2. I'd guess (Having never seen a YJ harness) that each large feed wire coming of the starter solenoid and coming into the tub will have a fuseable link. You're right... if the link blows, or opens, that circuit is dead... no voltage.
Safe Jeepin'
Larry
post #10 of (permalink) Old 01-08-2001, 12:38 PM
hey guys,
thanks for the info. it turned out that the fusible link between the battery and the alternator were fried. the battery to starter were ok though and that is why it ran.
the fusible link from my CJ was the same so now all is bettter
thanks
[b]Boston Mangler
See It At:
