Tranny-Transfer Case Lube Tranfer Problem - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-06-2001, 04:46 PM Thread Starter
I'm having a gear oil transfer problem between the T150 and Model 20 transfer case in my '79 CJ-7. Twice now, I've found lube leaking on the floor only to discover that the transmission is very low and the transfer case very full. I think it eventually leaks out the vent on the rear bearing cap of the transfer case (sound right?). I've drained the x-fer case to the correct level and filled the T150, but the problem returns. What could the problem be? All replies greatly appreciated!
Zeke
zeke is offline
post #2 of (permalink) Old 01-06-2001, 06:18 PM Thread Starter
Re: Tranny-Transfer Case Lube Tranfer Problem
I just got off the phone with a friend and he suggested the cause is a bad seal where the transmission and transfer case join. Does this sound like a good possibility? I'd like to be reasonably sure before I tear it out, but I suppose that is inevitable. Apparently the lube in the the transmission and x-fer case are meant to be separate and not be able to flow back and forth.
Zeke
zeke is offline
post #3 of (permalink) Old 01-06-2001, 07:45 PM
I Do This For The Glory
JEEPN's Avatar
Yes, it's about a $5 part. Same thing with my SM465/NP205, there is a seal in the adapter mating the two to keep the two fluids separate.
JEEPN
Winter Harbor, Maine
'81 CJ-8 Scrambled!
JEEPN is offline
post #4 of (permalink) Old 01-06-2001, 09:51 PM Thread Starter
JEEPN,
Thanks for the reply. Are you talking about the transmission rear bearing adapter and accompanying seal? I went ahead and pulled the unit and split the two gear boxes. I couldn't immediately see how oil could get from one to the other, but perhaps the seal on the bearing adapter explains it. Are you sure? Is there any other way oil could transfer? I see a port in the transfer case, but it's butted up against a wall on the transmission so I don't see how it could leak through. I plan to use RTV between the mating surfaces of the gear boxes upon reassembly. Is there anything special I should know on where to apply the sealant? Thanks a million!
Zeke
zeke is offline
post #5 of (permalink) Old 01-06-2001, 10:44 PM
JEEPN's Avatar
Man, I wish I had the scanner running. I need to upgrade to Win98 or above to get it to work, only one more week...
It's on Page 2B-5 , Volume 2 (Chassis) of the Factory Technical Service Manual. It's an awesome set, if you ever find the manuals, pick them up, they're worth it. Heck, I don't even have anything in that era, but just having the manuals helps everyone out.
Yes, it's the "Mainshaft rear oil seal", between the "locknut and washer" and the "oil slinger", which is next to the bearing. You should be able to undo the locknut, remove the seal, put a new one in, and torque it to 150 ft-lbs. Then re-attach the case and torque those bolts to 30 ft-lbs. It says here "Be sure the seal is installed so the metal side of the seal faces the rear bearing and the seal lip faces away from the bearing and toward the rear of the transmission". It even has a nice diagram. It does say "Install mainshaft rear oil seal in rear bearing adapter using tool J-26852", which looks like a hollow pipe you tap the seal on with. It's got a funny shape though, so it's undoubtedly more exacting than that.
Yes, I'd use the RTV as well, but just on the outside to seal against the elements. Put it together with the RTV, then snug it up, allow the RTV to set, then tighten to torque specs.
If I can be of further help, please let me know.
JEEPN
'81 CJ-8 Scrambled!
JEEPN is offline
post #6 of (permalink) Old 01-07-2001, 01:20 PM Thread Starter
JEEPN,
Hey thanks! That's just the info I needed, especially about the correct way to install the seal. I'm going to replace the T/O bearing and other seals since the gear boxes are out.
Zeke
zeke is offline
post #7 of (permalink) Old 01-07-2001, 01:52 PM
JEEPN's Avatar
No problem, glad I could help. When I get my scanner up and running I'll be able to post the entire page, so if you have any other questions, don't hesitate to ask.
JEEPN
'81 CJ-8 Scrambled!
JEEPN is offline
post #8 of (permalink) Old 01-08-2001, 05:24 PM Thread Starter
Wow, I didn't even have the "oil slinger" as described above and when I called around to find one, everyone said there is no such thing. I got ahold of the dealer who admitted that the part does exist, but was discontinued. They faxed the diagram showing the part and the OEM part number. They hooked me up with an outfit back East (relative to Oregon) and they had eight for $1 each! Apparently there was a tech. service bulletin way back when and the slinger was the fix for the oil transfer problem. So, if anyone is having this problem and needs the slinger, I've got a contact.
Zeke
zeke is offline
