rusty, sticky leaf springs - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-05-2001, 08:36 AM
I used spray grafite on my leaf spring and it seemed to help them slide along each other better, does anyone know of a better idea? I live in the snow/rust belt and have tried oil , but it just attracts crud. I have heard people using grease but with the same drawbacks
89 YJ 258, lime green, 4" lift, no track bar, manual axle disconnect
post #2 of (permalink) Old 01-05-2001, 09:27 AM
I Do This For The Glory
JEEPN's Avatar
Re: rusty, sticky leaf springs
Teflon pads as well, Jeepskate did this with his. I'm also going to do this when it's back on all 4, and the *Turtle Shell* is back on it. Then again, with the weight, I may not need it.
JEEPN
Winter Harbor, Maine
'81 CJ-8 Scrambled!
JEEPN is offline
post #3 of (permalink) Old 01-05-2001, 09:34 AM
i may have used the same stuff, its call "Slick-Plate" and it got it at a heavy equipment place. you could also install your own teflon pads. what you need is some teflon, uhmw, etc. sheet and some 3M weatherstrip adhesive. cut the plastic into squares the same size as the width of your springs. undo the clamps that hold your spring packs together. i used an air-chisel to seperate the leaves, but a big chisel or screw-driver should work too. follow the directions fot the adhesive and put it and the plastic in at the tips of the springs. let the jeep sit over-night to ensure a complete cure of the adhesive. if you take your apring-packs completely a-part, i would "Slick-Plate" after gluing the teflon down. if you need a supplier for the teflon, try www.mcmaster.com do a search for part # 8752K211. hope this helps! matt
jeepnmatt is offline
