Timing Control? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-02-2001, 01:43 PM
Timing Control?
I have done a Computer bypass on my 88 yj 4.2 carter, but my timing is constantly alternating between 6*ATDC and 9*BTDC?
Does the ignition module control timing to?
The vacuum advance works fine, but I know it is not supposed to do this.
Is there a mechanical thing in the distributor that is screwed?
thnx.
KEEP ON JEEPIN!
post #2 of (permalink) Old 01-03-2001, 09:19 AM
Re: Timing Control?
You have a mechanical advance device in the distributor. This is why timing is set @ 1600rpm. It takes the mechanical advance out of the picture...If you have a repair manual, it will explain what is going on in the distributor and how to test to see if everything is working. Good luck....
Tommy B. in AZ -
More Guts than Brains.
post #3 of (permalink) Old 01-03-2001, 02:33 PM
Re: Timing Control?
The ignition module does not advance or retard the timing. The knock sensor sends a signal to the ECM. This is what controlled the timing. And the control is only a few degrees, nothing major. But since you have done the Nutter Bypass the problem goes back to:
Distributor,
Timing Chain/gears or,
Vacuum.
Safe Jeepin'
Larry
