timing my 304 - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-30-2000, 04:51 PM
timing my 304
i have a cj with a 304 and it has some spark nock so i need to reset the timing what degree do i set it at. i have herd 8 degrees berfore tdc and have herd 12 before tdc. also what should i gap my plugs at. i have the tr upgrade. with the the tfi coil. thanks
80 cj7 304, WC t-5
post #2 of (permalink) Old 12-30-2000, 07:53 PM
Re: timing my 304
In most cases, the two timing degrees you have should work. Adjust the timing somewhere between the 8 & 12 degrees BTDC....wherever it seems to run best between those two marks. Advance the timing as much as you can between the 8 & 12 marks so that you don't experience any engine knock or pining. In a lot of instances, the type of transmission and what sort of emission equipment you have installed will cause discrepencies on what the true timing should be set at, but between 8 & 12 should work in the majority of cases.
Sorry, not sure what the gap on your plugs should be, although I know it has been discussed on this board in the past.
--Digger--
http://www.users.qwest.net/~ascanlon
post #3 of (permalink) Old 12-31-2000, 03:15 PM
Re: timing my 304
I'll add my .02 (may not be worth that much) I also have a 304 and TR/TFI upgrade. I have my timing at about 14-16 degress BTDC and no knock, at least as far as I can tell. Though my hear for such things may not be that great. I gapped my plugs at .040 though I believe, others have said that you can go up to .045-.050, maybe. HTH. Regards,
rich
77cj7304QtracTH400
79cj7frame,ready to be built
83cj7inpieces
"They can have my guns, but they'll have to take them bullets first."
fratt77CJ7 is offline
