Please help me sell my JEEP - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-30-2000, 10:23 AM
1987 Jeep Wrangler
Drivetrain
94 350 LT1 tuned port(upper) 74 LT1 (lower end) 10.5:1 comp
Hypertech 1986 Corvette 5.7 TPI Stage 2 Powerchip and Powerstat and distrbutor
Dart series II heads and Valve covers
Comp Cams hydraulic cam and lifters CS X4 254H-11
Pushrods 5/16" SBC Flat Tappet
ARP head bolt stud
Fel-Pro gaskets
8-1/4 deep sump Moroso oil pan w/ high pressure oil pump
24lbs Fuel injectors
Cold air induction with K&N
MSD Cap, rotor and 8.5mm Wires
Power Coil kit
Howe Aluminum Radiator
Electric puller fan on thermostat (factory fan removed)
Flowmaster headers 3inch collector into 3inch custom bent tubing into a Cat and in to a 2 Chamber Flowmaster
TH350 Transmission rebuilt with extra Borg Warner clutches, a heavy
duty Race, Kevlar HP band, adjustable Red Stripe modulator, all metal
thrust washers, new bushings, chrome pan with drain plug, performance
shift kit, worked valve body, RV/towing torque converter and more
Advanced Adapters mounts for motor, transmission, and transfer case
NP231 Transfer case rebuilt
91 Custom rear drive shaft balanced with HD 1310 U-Joints
Dynatrac Dana 44 rear (out of 1987 Jeep Cherokee Police special) with
3.73 and locker
Dana 35 (out of 95 Jeep) with 3.73 and automatic vacuum operated hubs
High performance Paxton fuel pump and filter with braided steel lines
to and from tank
High pressure gauge and regulator
Lift
Rough Country 4inch lift with ES3000 shocks and single steering
stabalizer
Extended braided steel brake lines
Extended swaybar links
Extended Breather hoses
Lengthened Driveshafts
1-3/4 Conn-Ferr shackle lift
2 inch Procomp body lift
Exterior
99' Jeep front bumper
Hardtop with 5% tint all around
Hard doors with 20% tint
Chrome rear bumperettes
4-15x8 Weld SS II wheels
4- 35x12.50/15 Goodyear Wrangler MT/R (brand new)
New rubber undercoating
Underhood lock kit
New sandblasted and painted frame
Custom Skid plate protecting trans and transfer case
Interior
95' Jeep Wrangler tilt wheel and column
99' Jeep Wrangler Roll bar
SunPro Supertach in factory spot
Autometer Air/Fuel mixture gauge in factory clock spot
Alpine 3CD in dash detachable face Cd player
After market Alpine 11 band EQ
Alpine V-12 PVM Regulated Power Supply 2/1 Channel amp running 2-8"
Cerwin-Vega subs in custom box
Alpine V-12 DC Straight 4/3/2 Channel amp running 2-4" 2-way
Cerwin-Vega dash speakers and 2- 6-1/2"speakers in overhead sound bar
New carpet and floor mats
New aftermarket Jeep seats
New fold and tumble rear seat
Locking center console
I have alot of $$$$$$ invested and have over $15,000 in recipts I am asking $13,000, nut make me an offer I must sell and I need the money bad!!! So if you have a partial trade or all the $$$$$$ just let me know we can work something out HELP!!!!!!!!!
1987 Wrangler
350 TPI
7 inch lift and 35's
