Voltage guage question - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-21-2000, 08:18 AM
Driving home from work yesterday. The voltage guage started spiking up to 16 volts. (Just before the red area). I tapped on the guage glass and it fell back down to 14ish like it normally shows. Then went back up to 16 a while later. Tapped the glass and went back down to 14...So do you guys think the guage is bad? Or should I start taking some readings to see what the actual voltage is coming across there?
Thanks,
Tommy B. in AZ -
More Guts than Brains.
post #2 of (permalink) Old 12-21-2000, 09:03 AM
Re: Voltage guage question
I use to have to bang mine to get it to jump off 8 volts. Something might be making the voltage spike and the needle in the gauge is getting stuck. Check the wires on your voltage reg. This was usually my problem also.
Pigpen
Pigpen is offline
post #3 of (permalink) Old 12-21-2000, 09:45 AM
It seems you have accuratly diagnoised the "Thump" factor for the guage. Nomally a gauge, when it goes bad under reports the voltage. In a few rare cases, it over reports. Just as a double check, do the following:
1. Check the voltage at the battery at idle and at about 2000 RPM, it should not be over 14.7 volts as measured by a DVM.
2. Remove the connectors on the back side of the dash mounted volg meter, and reconnect them about three times to break down any tarnish on the connectons.
3. When doing number 2 above, make sure the connections are not loose.
Then, if everything else checks out fine, and the meter still over reports when you tap on the glass, replace the meter.
Happy Holidays and Safe Jeepin'
Larry
post #4 of (permalink) Old 12-21-2000, 02:27 PM
I recalibrated the guage in my 95 YJ after I determined it wasn't reading accurately. There was a small magnet inside the guage that could be repositioned to get an accurate reading.
jerry
jerry is offline
post #5 of (permalink) Old 12-21-2000, 03:48 PM
FlMudCJ
I've re-calibrated my brain to correctly read the voltmeter guadge. When it's pegged off, the ignition is off, or battery dead. When it indicates 14.5 volts, it really is 12V battery voltage, and when pegged 16+ its 14.5v alternator power. Its consistent and the voltmeter didn't show anything to be concerned about. Haven't blownup a battery, and everything's been fine and dandy, so no need to fix it.
Its a jeep thing, gives it character. (yeah, that's what I'm calling it now)
'77 CJ-5: 304/T-150/D-20 F-D44 R-9" Power 4 wheel disk, 36X12.5 swampers
bigmudtire
post #6 of (permalink) Old 12-21-2000, 03:59 PM
Ok guys, take it from an electronics Guru... we've got several different situtations here....
There is a vast differnece between consistant over or under reporting by a meter and one that sometimes reports one voltage and sometimes reports another and can be corrected by hitting it.
Constant, but correct operation can be corrected for with the zero adjustment, or simple brain re-education.
However, when something is inconsistant.... it means trouble and if you don't fix it, or understand the trouble, it will put your vehicle at peril. By thumping the glass it shows the meter is sticking... not just innacurrate, but sticking. So if you recalibrate it with the zero adjust or with brain re-education you are sticking your head in the sand and saying there is no problem. Remember, in your examples above the symptoms are all different as are the conclusions and the workarounds.
I still stress, fix the meter, or understand the problem before you take the vehicle off road. What can happen is that you take an incorrect workaround and find yourself destroying your battery becasue the meter is inaccurate. That's the danger in not undestanding the source of a problem. By masking it, you put yourself and any riders in your Jeep at peril while off road.
This maybe a simple thing.. but it's a safety thing.. and first and foremost in every Off-Roader should be the safety of their passangers and themselves. Remember the old computer thought: GIGI? Garbage In Garbage Out. This is no different. You're getting garbage input from the meter and betting that it's accurate. Someday, even when you thump the glass, it won't be accurate and that's the day you start to walk out.
Replace the meter.
Larry
post #7 of (permalink) Old 12-22-2000, 10:02 AM
Thanks Larry, I will check the voltage at the battery etc, like you explained. If the voltage is ok there does it mean the voltage regulator is ok? The guage just doesn't stay at 16 all the time. It bounces all around (between 14 and 16) and sometimes sticks at 16. That is when I tap the glass to get it back to 14ish. I turned the engine off and checked the guage again with just the key turned on. It read only 8 volts...Tapped on the glass and it jumped back up to 14ish...But still bounced around even with the engine off.. Guage or something else???
Tommy B. in AZ -
post #8 of (permalink) Old 12-22-2000, 12:30 PM
I'd guess your alternator and regulator are OK, or you'd be replacing an overcharged batttery. So let's go over this again in a little more detail talking about current draw and voltage regulation.... with the starter, the headlights. and the heater blower motor. They often cause the voltage meter to report all over the place. Also you've probably seen the headlights dim when the blower motor is turned on untill you bump up the RPM a bit.
The problem you are seeing of the voltage level at the meter on the dash is not unusual. There are voltage drops between the varied subsystems of the Jeep due to ground problems an corrosion on the voltage gauge terminals.
There are three grounds on the Jeep, one cable from the battery to the engine block, a ground strap from the engine block to the frame and a ground strap from the frame to the tub. Also, on some models there is an additional wire connecting the tub firewall to the negative side of the battery. This small wire also acts as a ground.
If any of these are compromised with corrosion, resistance sets in and causes differing problems with the electrical system. As an example on my 1983 CJ7, the negative battery cable was corroded where it affixed to the engine block. All the starting current for the starter motor then went:
From the battery.
Through the cable to the starter solenoid.
Through the starter solenoid to the starter.
Through the starter to the engine block.
Then instead of returning to the battery through the engine block and though the negative battery cable the electricity was forced to return:
Though the frame.
To the engine ground strap.
Through the engine ground strap.
Through the ground strap to the Tub... but that did not exist.
So all the current went though that little tiny wire on the fire wall to the battery.
Well, as you can only imagine, the wire smoked and melted the insulation. It could not handle the current. That's the day I learned about the ground loops in a Jeep.
Of course the other problem endemic to a Jeep is water pouring through the windsshield frame cowl gasket and into the dash area. Then everything behind the dash becomes quite soggy and moist. As it dries out corrosion forms on the connections and voltage drops occur.
Another example would be the heater blower motor fan. As you turn on the fan the blower motor's electric return path is:
From the battery to the fuse box.
Through the ignition switch
Through the supply fuse.
Through the on/off switch.
Through the speed selector.
Through the speed dropping resistors, if selected.
Back through the wring harness and fuse block.
Through the blower motor.
Through the metal back plane of the heater box.
Through the mounting stud of the heater box to the tub firewall.
Through the firewall (tub ground) back to one of the three grounds to the battery.
As you can see, there are several areas that resistance can build up. Just look a the heater box mounting studs. They have star washers on the nuts to help insure a good ground... but over the years corrosion sets in where the star washer has scared the paint. A voltage drop occurs. Now due to a higher resistance of the voltage path, the blower motor pulls more current and the lights dim when it's switched on.
Add to this the lights. Their current path is as follows.
From the battery
Through the fues box.
Through the fuse.
Through the headlight relay
Through the wiring harness
Through the lamp, itself.
Through the return wire to ground.
Through the ground wire to the grill
Remember the grill sits on a bushing mounted to the frame.. usually it's pretty corroded and not a good ground via the bolt the frame.
Through the grill to the fenders.
Through the fenders to the tub ground.
Then back to the battery via one of the three grounds.
Put the headlights on high, and with ANY type of ground loop resistance, a high current application has just become higher. The voltage gauge responds accordingly, as it sees the voltage drop in the tub. The alternator can't keep up with the draw and you see an increase in brightness of the headlights, and an increase in voltage on the gauge, as you increase the RPM's.
In both cases above, however, if you put a volt meter on the battery terminal... I would doubt you'd see a great difference in voltage.
Another source of failure is the thick red wire going from the alternator to the battery side of the starter solenoid. This wire breaks down over time, as it carries all the charging current to the battery and supplies the current to run the vehicle. As it breaks down resistance builds up and it can and will fail.
To make a long note short: First clean ALL the grounds, battery cable connections, alternator connections and voltage gauge terminals. This should restore the accuracy of the ground loops.
Now again put on the lights, do they dim at idle? Probably not.
Now put on the Fan, does it dim the lights at idle? Probably not.
However, if your Voltage gauge is reacting to the current load and the connections have been checked, I suggest changing the meter. There should be a load differential when you first turn on a high current device. It will take a second or two for the alternator to sense the load, and increase the voltage output. That's normal to see the gauge react to the spike. However it's not normal for the gauge to bounce all over it's range, say from 9 volts to 15 volts. This would mean a problem...
But to compound the problem your meter is sticking... even with the engine off it cannot report a steady voltage unless you tap on it. This means the meter movement in the gauge is sticking. As you tap on it, the meter movement is able to overcome the resistance that's causing it to stick and report the higher... or lower voltage, depending upon the swing it was in when it stuck. So, the meter is compromised.
Which is more accurate, a mechanical clock that's broken and doesen't move or an clock that looses or gains time?
Well, the answer is the cloc that's broken is more accurate. It is right twice a day, when the time on the face and the actual time are the same.
The innacurate clock is always close, but never on time, never accurate.
It's much the same for your meter, it's never accurate, and IMHO it never will be. Get rid of the meter, or put an auxilary meter that is accurate, and you can trust, somewhere under the dash.
Larry
post #9 of (permalink) Old 12-22-2000, 12:58 PM
Thanks again for all the advice. Everything you said made perfect sense... I checked the headlights yesterday with the heat and radio on. There was no change in brightness at all whether just idling or reved up or whether I turned something on or off. I cleaned all the grounds/battery connections last month when you mentioned that in one of your other posts. [img]/wwwthreads_images/icons/smile.gif[/img] I will clean the alternator and guage conns today. Is the voltage regulator attached to the firewall under the battery with all those wires attaching to it? If it is, I noticed a lot of corrosion on that thing. I will clean that also. I am really thinking its the guage though. My fuel guage went out a couple of months ago and did the same bouncy thing...The fuel guage for the Wranglers cost $45. I'm hoping the voltage guage isn't that much. I really appreciate your help and hope you and your family have a great Christmas....
Tommy B. in AZ -
post #10 of (permalink) Old 12-22-2000, 01:22 PM
Sorry about the ignorance on the YJ, but I'm not sure where the regulator is... I suspect that it's internal to the alternator. If anyone has scans for the YJ and XJ schematics... send 'em my way.
Not bieng politically correct... Merry Christmas!
Larry
