Steering does not recenter on turns - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-20-2000, 12:52 AM Thread Starter
Anyone have any ideas why the steering would not recenter on the exit of a turn?
I have a 3" Dick Cepek lift with 32" tires and a stabilizer. I just purchased this CJ7 and these items were all installed.
Is this just a cause of larger than stock tires? Or would this be a symptom of an alignment problem?
I am getting used to spinning it back straight, but it realy sucks!
Thanks
BigHG is offline
post #2 of (permalink) Old 12-20-2000, 04:28 AM
jeepgod's Avatar
Re: Steering does not recenter on turns
well usually when it doesnt center itself.. its because the caster angle is bad.. what that angle is the the angle of your ball joints.. you have a top and bottom one.. just inside the tire at the end of the axle.. they should have somewhere in the nieghborhood of +6 degrees of caster.. meaning the top ball joint is just tilting to the rear of the jeep.. if its pretty much straight up and down.. somewhere around 0 degrees of caster and if the top one is tilting towards the front of the jeep.. then that is negative caster and that is bad..
what probably happened was they might have installed some shims under the axle in the front when they put that lift on.. most come with these.. take a look up under there.. they will be between the springs and the axle (spring perch) will be a small shim in there.. you can take those out and it will bring the axle back to stock.. and should solve your problem..
they put that shim there for front driveshaft purposes.. and you rarely use it.. except when off roading and going slower than normal.. so a slight angle on it wont hurt it..
http://www.jeepgod.net
jeepgod is offline
post #3 of (permalink) Old 12-20-2000, 06:56 AM
good call Jeepgod. I think its the same thing.
Was that lift just added? did you start noticing this after you installed the lift? Or was it a surprise? If you had shims, maybe one fell out.
good luck
[b]Boston Mangler
CJ7 With A Bunch Of Goodies
See It At:
http://ct-web.unh.edu/yankeetoys/kspeicher/
post #4 of (permalink) Old 12-20-2000, 07:17 AM
Does it have a shackle lift in the front (which would also change the caster)? Other than that,I second what jeepgod said.
Tom
post #5 of (permalink) Old 12-20-2000, 08:43 AM
Another possibility being that the new steering stabilizer is a real stiff one, and that, combined with improper caseter angle will make it more difficult to return to center.
mike
Give me Jeep or Give me Death!!!
(Will trade functioning organs for CJ-7 or flatfender)
post #6 of (permalink) Old 12-20-2000, 10:33 AM
It could possible be some thing simpler than JeepGod came up with, check the tires see if they are radials or bias ply tires some bias ply tires will not return to center after a turn.
