How much slip should a limitted-slip slip? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-19-2000, 11:52 PM
I've got an AMC20 rear diff in my CJ5 and I'm pretty sure the clutches are bagged in the Trak Lock (correct name?) limitted-slip carrier. How difficult should it be to turn a wheel when one side is jacked up? I priced out a rebuild kit for it and decided its not worth it (better to save for locker).
post #2 of (permalink) Old 12-20-2000, 01:36 AM
Smokngun's Avatar
Re: How much slip should a limitted-slip slip?
I've had factory limited slips in a number of vehicles and I couldn't turn any of them by hand with it jacked up. With vehicle weight on the tires and turning a corner is a different story. For the cost of a rebuilt factory LS, you are better off getting a locker, or if your driving style requires a "Looser" diff, then go with an Eaton Posi. I've heard they are very good quality.
Mike H.
1983 CJ-7 Laredo, Down to the bare frame...parts everywhere!
2000 Durango SLT
I can't go to work today...the voices said "Stay home and clean your guns!"
Smokngun is offline
post #3 of (permalink) Old 12-20-2000, 08:52 AM
Remember when getting a locker such as Lock Right you will need the stock carrier. The LS carrier cannot be used so add $60 for the standard carrier if going in that direction. I have found that the LS in the rear works fine and spent my money on the locker up front where when off roading really makes the difference. I have redone the clutch in the AMC20. It's fairly simple and can be done on the bench with no special tools. Clutches are only @ $70.
Pigpen
Pigpen is offline
post #4 of (permalink) Old 12-20-2000, 10:34 AM
I Do This For The Glory
JEEPN's Avatar
If a limited slip should slip, it would slip only as much as a limited slip should slip.
Just trying to equate this to the "Wood Chuck" analogy.
If you jack up both tires, with it in neutral, and spin one, and the other doesn't move in the same direction, it's worn out. Clutches are only $60 to $70 and rebuilding them is a snap.
JEEPN
Winter Harbor, Maine
'81 CJ-8 Scrambled!
JEEPN is offline
