Anyone running a T18/NP205 or NP435/NP205 w/258? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-15-2000, 09:03 PM Thread Starter
TOM85CJ7's Avatar
First of all I am considering a tranny swap. I have a T-176 so I know that either the T-18 or NP435 will bolt right in. I would rather not purchase an adapter for my Dana 300 so I was thinking about doing a complet tranny/Tcase swap. Does the NP205 have the same outputs as the Dana300? What about the overall length of the cases, will I have any rear driveshaft? Is anyone running this setup in their CJ?
Thanks,
Tom
http://home.off-road.com/~tom85cj7/home.htm
TOM85CJ7 is offline
post #2 of (permalink) Old 12-15-2000, 09:44 PM Thread Starter
TOM85CJ7's Avatar
Re: Anyone running a T18/NP205 or NP435/NP205 w/258?
Hey,
I bet nobody uses the NP205 because it only has a 1.96:1 Low range....
No wonder I can't find any write-ups.
Later.....
TOM85CJ7 is offline
post #3 of (permalink) Old 12-17-2000, 09:57 AM
I Do This For The Glory
JEEPN's Avatar
Wel, the only problem is the NP435 and T-18 are both Ford trannies (you knew this), but the NP205 that came with them has a driver's side drop, not the passenger's side you need. I am running the SM465/NP205 setup in my scrambler, and it's only 3.5" longer than the stock SR-4/D300 combo that was in there. I do know of someone that is running a NP435 in their Scrambler, but they needed an adapter to run the D300 for the correct side. If you wanted to swap front axles to a Ford one, to get the driver's drop, it should work. Hey, just coil it while you're at it!
JEEPN
Winter Harbor, Maine
'81 CJ-8 Scrambled!
JEEPN is offline
post #4 of (permalink) Old 12-17-2000, 05:29 PM Thread Starter
TOM85CJ7's Avatar
I new there was a reason everyone wasn't doing this. The adapter for NP435 to Dana300 is around $500. Not worth it for me. I think I will consider the 4:1 kit for my D300.
Thanks for the input....
TOM85CJ7 is offline
post #5 of (permalink) Old 12-17-2000, 11:05 PM
the 4to1 kit costs more than the tranny adapter so why go that route?
brian wilson
80 cj5 "high 5"
stretched to 100" wb
efi351w/np435/d300/d44/d60/detroits/4.56/35tsl's/
post #6 of (permalink) Old 12-17-2000, 11:20 PM
because he wont have to buy the tranny also
mike34 is offline
post #7 of (permalink) Old 12-18-2000, 08:32 AM
true but still less than $100 difference. the going rate for t-18's and np435's (junkyard/used) is around $200 and the adapter for the np435 to a dana 20 or 300 x-case can be found for less than $500. i got mine for $445 from hicks (it was a few years ago though). the 4to1 gears run over $600. it's just my opinion that i would rather spend a few extra dollars if it ment i wag going to end up with a stronger tranny. just my op.
brian wilson
80 cj5 "high 5"
post #8 of (permalink) Old 12-18-2000, 09:37 PM Thread Starter
TOM85CJ7's Avatar
I was thinking that it would cost less to do the 4:1. Because I won't have to buy the tranny, adapter, and I can keep my current driveshafts. I can do the 4:1 and rebuild my D300 at the same time. Then later if I blow my tranny I can consider a swap. For now both my tranny and tcase are working fine. My main consideration for a swap was improving my crawl ratio. The cheapest and easiest route is the 4:1.
Thanks for the replies,
Tom
TOM85CJ7 is offline
