All New Gas Rig Still Wont Run, HELP :o( - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-12-2000, 11:03 AM
Hey Guys,
I just went out and bought a 5 gallon gas tank, filled it with premium new gas and replaced all the gas lines on my truck and then put the hose that feeds the fuel pump and ran it for about 10 mins or so with the new gas and it still sputters and chokes like it wants to die. I then bypassed the fuel filter (in case it was clogged) and got the same results. I guess the gas was not bad, or at least that it not my problem. The fuel pump was pumping, how much i dont know but it was pumping.
Anyone have ideas what it could be? Stuck valve? (how could i tell).
Anyone have a source for a nice and detailed Vacuum diagram they could send me? I am still waiting delivery of my FSM. I have a 79 CJ with the stock 6cyl.
Thanks A Lot
[b]Boston Mangler
CJ7 With A Bunch Of Goodies
See It At:
http://ct-web.unh.edu/yankeetoys/kspeicher/
post #2 of (permalink) Old 12-12-2000, 11:20 AM
Re: All New Gas Rig Still Wont Run, HELP :o(
[img]/wwwthreads_images/icons/smile.gif[/img] My moonguys say to tell you that it sounds like a vacuum leak. Between the intake and the head or somewhere under the carb, or maybe an EGR valve. I have all the vacuum schematics for the '79 V8 AMC but not the six-bangers.[img]/wwwthreads_images/icons/tongue.gif[/img]
CJDave
CJDave is offline
post #3 of (permalink) Old 12-12-2000, 11:40 AM
thanks dave
i just dont get it. it ran awesome before it sat though.
[b]Boston Mangler
See It At:
post #4 of (permalink) Old 12-12-2000, 11:41 AM
Pete88YJ's Avatar
stuck valve finder = compression test.
Good luck
Pete [img]/wwwthreads_images/icons/cool.gif[/img]
http://ourworld.compuserve.com/homep...gyver/jeep.htm
Pete88YJ is offline
post #5 of (permalink) Old 12-12-2000, 12:51 PM
Have you maybe thought that it's not a fuel related problem then???.. as long as you smell gas and the carb is "gassy" then that part is good... have you checked your electrical system lately?>... what kind of wheelin did you do on saturday anyway... that can have a lot to do with it... if it was really bumpy. then maybe more towards a vacuum leak, but if it was really wet.... then try taking off your distributer cap and having a look.... spray it w/ WD40 and put it back on in the same place and give er a try... but... if it sputters and turns ok... it should still run w/ a bad valve... trust me on this one. if still problems after checking out everything electrical, then check your valves and stuff.... just think back to what u did to it wheeling.... this should tell you A WHOLE LOT.
hope this helps any at all...
Jonathan
atroader 82cj7 5"susp 258 T5 D300
post #6 of (permalink) Old 12-12-2000, 01:58 PM
Just a thought,,, What if your timing is bad. You know 90% of timing chain failure occures with a warn chain and when the engine is shut of it jumps with out any notification. When you go to start it again it will either not run (big jump), or it runs crappy (little jump). Check your timing to make sure this didn't happen. Pull it to TDC on the crank and check where your rotor is pointing should be fairly close to #1.
GP'n
GP'n is offline
post #7 of (permalink) Old 12-12-2000, 02:23 PM
***** Yup, brand new coil, cap, rotor, plugs, wires, ignition module, etc..
***** I didnt go wheeling Saturday, my rig isnt driveable
***** i am going to do a compression test in the AM
***** I have never wheeled this thing yet.
thanks
[b]Boston Mangler
See It At:
post #8 of (permalink) Old 12-12-2000, 02:25 PM
***** Someone else mentioned this and i think i have eliminate any problem but this
***** It runs nice and fairly smooth but it wont idle? is that a sympton?
***** How do i do that?
thanks
[b]Boston Mangler
See It At:
post #9 of (permalink) Old 12-12-2000, 02:31 PM
ok cool.... just some suggestions... when u said it ran on sat i assumed u wheeled it. i also wont reply to the tdc and dist. at # 1 cuz I assume you're joking>>>> take care and good luck
post #10 of (permalink) Old 12-12-2000, 02:36 PM
***** nope, i said it ran good before it Sat, meaning it sat for 8 months
***** Ah nope, i am serious. I just wanna make sure i do it 100% right?
thanks
[b]Boston Mangler
See It At:
