Picking angle for engine, tranny, t-case mount - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-10-2000, 09:59 PM
Ok, let's say you're starting with a 304 on its mounts, without a tranny or t-case, and you want to add the t-case and tranny while building a custom mount for them. How do you pick what angle to keep it all at? Would you try to keep the engine at the same angle it's at before anything is added? I'm re-doing my T-18 install, and refuse to lower the skidplate, so I'm cutting the bumps out of it and crafting a new support for the tranny, but am unsure what angle to mount it at to keep the most stress off of the motor mounts and bellhousing.
Moneyless, Will weld for jeep accessories.
post #2 of (permalink) Old 12-11-2000, 08:41 PM
jeepgod's Avatar
Re: Picking angle for engine, tranny, t-case mount
well dont know the exact angle.. but your engine should just slightly tilt towards the rear with all that hooked up behind it.. cant be more than a few degrees.. just enough to notice it.. i just eye balled mine.. but like you i didnt want anything hanging down.. so i also just kept the cross member even with the frame.. like stock.. but i had a slight tilt to the engine when i welded in the engine mounts.. its on my web page.. sorry for the lack of technical tongue..
http://www.jeepgod.net
jeepgod is offline
post #3 of (permalink) Old 12-11-2000, 11:10 PM
FarmJeep-
I thought that you almost killed yourself getting that T-18 into your Jeep. Hope all goes better on the redo.
I was watching TRUCKS on TNN one day and they were putting a new crate motor in a 30's truck (2 wheel drive). They were using Advanced Adaptor motor mounts and built a cross member for the tranny. I believe that they were talking about a 9 degree angle. Of course, they had a cool tool to measure the angle with.
Why not remove the spacers and push the skid plate up? I have been told to not use spacers on my skid plate for the CJ T-18 swap that I am about to do. (78 CJ5 304) Is the fact that yours is a Ford T-18 the issue?
Good Luck!
Kriss
post #4 of (permalink) Old 12-12-2000, 09:41 AM
I've got the CJ t-18. From the factory, they came with spacers, believe it or not! Without the spacers, the lump on the bottom of the tranny (where the drain plug is) hits a bump on the skidplate, causing the tranny to rest on that bump, putting mucho strain on the motor mounts, bellhousing, etc. You'll have to modify something to make it work. Either drop the skid plate with lowering plates, or clearance it to make the tranny fit without hitting.
I've enlisted a friend for the second t-18 installation session...
