firing order on a 258 - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-10-2000, 03:49 PM
I am using 1 5 3 6 2 4 but it doesn't work.
post #2 of (permalink) Old 12-10-2000, 04:20 PM
Re: firing order on a 258
That's the proper firing order, check it again. Maybe your distributor is 180 degrees off. That's all I can think of right now. Maybe someone else will have more ideas on your problem, also try giving more details on your problem.
Ben
winchboy is offline
post #3 of (permalink) Old 12-10-2000, 05:18 PM
If you are refering to a 258 I6 and mean the firing of the plugs as the engine is turning trying to start, then you have the right firing order. But on the other hand if you are working on a 2.5 I4 or 304 V8 then this will not work. What are you doing????? Need more input from person asking What question!!!!!!!!!!!!!!
GP'n
GP'n is offline
post #4 of (permalink) Old 12-10-2000, 06:59 PM
<font face="Comic Sans MS">You need to verify two things. Those things are: [*] Verify that your rotor is pointing at the terminal your #1 plug wire is on when the engine is at TDC (or better still, when the engine is at whatever you have your base timing set to) on cylinder # 1.[*] Verify that you have the wires oriented correctly (clockwise or counterclockwise (not sure which it would be on that particular one, but you could tell by cranking the engine over and watching the rotor.)).
Just some thoughts... </font>
Tim
ORC Land Use columnist
My November article on ORC
http://www.off-road.com/land
The_Sandman_454 is offline
post #5 of (permalink) Old 12-10-2000, 07:49 PM
My distributor was 180 degrees off. She run's fine now. Thanks.
post #6 of (permalink) Old 12-11-2000, 08:46 PM
Does having the distributor 180 degrees off make any difference in preformanc?
post #7 of (permalink) Old 12-11-2000, 10:55 PM
If the distributor is firinng 180 degrees out the spark event will be happening on or about TDC of the exhaust stroke instead of the compression stroke. also some engines the distributor must be installed absolutely correctly for proper operation due to uneven firing orders, examples: 90 degree V6s, air cooled volkswagens....
Also an easy way to remember I6 firing order: Too young, Too old, Just right, 15,36,24 dirty old men think these things up.
good luck, jjc
