Please tell me why new T-out bearing went bad - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-09-2000, 10:34 PM Thread Starter
Okay, so after the fiasco of goofing up my first t-out bearing install, I put in a new one a month ago. Today I heard the new one squealing!![img]/wwwthreads_images/icons/mad.gif[/img]
Please tell me why that sucker went bad so fast. I think that is the third one in a year or so. I don't really buy that it was a bad part. Knowing how my Jeep sometimes eats new parts for breakfast, I think it's something in the Jeep and not the part.
Thanks
Sean
Reitman is offline
post #2 of (permalink) Old 12-09-2000, 10:47 PM
Re: Please tell me why new T-out bearing went bad
Hmm. VERY frustrating. Some suggestions. Is the fork boot torn, letting dirt and water in. Are you pressure washing the underside of your Jeep and getting degreaser or soap into the bearing. Is the bearing retainer that it rides on worn or scored (VERY common problem). Hope this helps, I feel for you, that job is a PITA.
Brad
ORC Land Use Section Editor
http://www.off-road.com/land
post #3 of (permalink) Old 12-09-2000, 11:00 PM
Is the throw-out bearing adjusted properly so that the bearing disengages when you let off the clutch? (Stops turning) Are you riding the clutch? Either one can make the bearing fail.
Just some thoughts!
Kriss
post #4 of (permalink) Old 12-09-2000, 11:06 PM
It is most likely just adjusted wrong and is still spinning all the time... you whould be able to hear it when the clutch isnt engaged... if that is the case just keep adjusting it off until it wont stay in contact.
post #5 of (permalink) Old 12-09-2000, 11:12 PM
That's exactly why I asked if the bearing retainer is scored. It may be keeping the bearing from releasing off the clutch, even if it is adjusted properly.
Brad
post #6 of (permalink) Old 12-10-2000, 12:36 AM Thread Starter
I'm only hearing the squealing when the clutch pedal is being pushed in or let out. It does not make noise any other time. Can I try poppoing the boot off and greasing the shaft it rides on?
God this makes me want to pull my hair out just thinking about yanking the tranny again.
Thank guys
Sean
Reitman is offline
post #7 of (permalink) Old 12-10-2000, 04:04 AM
i just replaced my t-bearing last week along with putting in a t-5 transmission. and i learned that its important to have the clutch lincages ajustes so that your t-bearing isn't being pushed up aginst your clutch spring things. back off the turnbuckle thing and maybe add a stronger sping to get to t-bearing to retract more.
80 cj7 304, WC t-5
post #8 of (permalink) Old 12-10-2000, 11:21 AM
That shaft that it rides on is actually the input shaft bearing retainer I've been referring to. It is easily scored, you might be able to get in there with the boot off with the vehicle on a lift. But like all the other posts said, make sure the linkage is adjusted properly too. BTW, did you grease the bearing retainer before you put it together, if not, that is probably your problem.
Brad
post #9 of (permalink) Old 12-11-2000, 08:58 AM
[img]/wwwthreads_images/icons/tongue.gif[/img] In over fourty years of serious wrenching, I have LOST TRACK of the number of clutch jobs I have done. In SO MANY cases, it was necessary to go to extremes.....like re-doing linkage....to get the super-perfect adjustment that I was looking for. In so many cases, linkage wear, scored retainer O.D. surfaces, and just plain crappy factory linkage DESIGN stood in the way of a good clean disengagement for the throwout bearing, and if I had not gone the extra mile, it would have resulted in premature throwout bearing wear. We even had a new tractor that had a throwout bearing failure. To his great peril, the service manager suggested that we were riding the clutch. That was a very big mistake for him to say that. I almost fed him the bearing right then and there. It was a clutch fork problem and required some machining to cure it.There was literally no room for the bearing to clear the throwout forks as manufactured.[img]/wwwthreads_images/icons/mad.gif[/img]
CJDave
CJDave is offline
post #10 of (permalink) Old 12-11-2000, 09:06 AM
Dirt Dog's Avatar
Like everybody else said.......
Make sure it's not spinning all the time.
I'm sure thats probally the problem.
I just wanted to throw my .02.
Make sure you buy the best one you can find. Not some discount cheapie.
My friends on his 3rd one in a little over a year.
He is finally going to listen this time.
It's always the same no matter what you are talking about.
"PAY ME NOW OR PAY ME LATER"
And BTW mud and water eats these things for lunch.[img]/wwwthreads_images/icons/crazy.gif[/img]
Lead , follow , or WINCH ME OUT!!!!
http://home1.gte.net/rythem/davescj7.htm
Dirt Dog is offline
