Dipstick tube for 258? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-09-2000, 03:43 AM Thread Starter
My dipstick tube from an '82 258 engine broke near the block. The tube is fairly long and has a bracket attached to the head and ends near the top of the distributor. When I got the replacement from the dealer, it was a short version without the bend. This seemed advantageous for a clean set-up, adn shorter dipstick. I installed with permetex aviation sealer. It looks like oil is coming out the top of the tube (only about 3-4 inches above where it enters the block.
Ok, here is the question. Can I buy a dipstick that seats or seals the top of the short tube? My wife's suburban has tranny dipstick that locks down like a boat plug. As you lock it down, it squeezes the rubber stopper inside the top of the tube.
I cut my original dipstick down to size, but the rubber at the handle end is probably old, brittle, and ineffective. Would a new dipstick do the trick, or does a short tube require something special?
TIA
I
-raymo
Scrambler
258 4.0 Head/MPI,NV4500,D300,4.10's,HS9500
raymo is offline
post #2 of (permalink) Old 12-09-2000, 03:49 AM
Re: Dipstick tube for 258?
Ray, check your email!
Happy Holidays and Safe Jeepin'
Larry
post #3 of (permalink) Old 12-09-2000, 02:49 PM
I bought a rebuilt motor from an eagle. It had the short dipstick tube. I tried to pull my long jeep tube from it's block and it broke off at the block. So I cut the long tube's bottom to make up for the length of the short tube, used a short piece of rubber hose with a clamp on each end to seal the two together, then used the bolt to hold it to the block. Now I have the same setup as original, and can use the original dipstick. I think you need the long tube for jeeping if you encounter water.
Tim in Manitoba
84 CJ7, 258, HEI, M/C 2100 carb, 5 inch lift, RS9000's, 33x12.5 BFG M/T's, Lockright, full cage & belts, Xenon flares, AMC 20 1pc axles, GM dual diaphragm brake booster
TiminMb is offline
