shims ( pinion ) - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-08-2000, 07:52 PM Thread Starter
shims ( pinion )
I have to replace my ring & pinion. Can I reuse my old shims in the axle or do I have to buy new ones?
Thanks for the info.
Garrett
90'/YJ/35c/411's
Garrett
90' YJ/2.5L/NP231
81' CJ-7 Frame build-up into CJ-8
G-JEEP is offline
post #2 of (permalink) Old 12-08-2000, 08:51 PM
Re: shims ( pinion )
The ones that are in there can be reused, JUST AS LONG AS THEY ARE THE THICKNESS YOU NEED FOR THE NEW R&P. To do a proper installation you will need a selection of shims to be able to set it up properly. The chances are against you using the same shims when you replace parts.
Brad
ORC Land Use Section Editor
http://www.off-road.com/land
post #3 of (permalink) Old 12-08-2000, 11:31 PM
Make sure when you install your new gears you use grease paint to paint the gears and make sure you get a good mesh pattern. Probably the best way to do this is get a book on axles. Thenyou can see pictures of a good mesh pattern. You will however need a new crush collor for the pinion gear because once they crush they cant be reused. hope this helps you out.
The baddest four letter word JEEP
post #4 of (permalink) Old 12-09-2000, 01:41 AM
Personally, i wouldnt be setting up my first set of gears in an axle i will depend on without supervision from someone who really knows whats going on....
mike
Give me Jeep or Give me Death!!!
(Will trade functioning organs for CJ-7 or flatfender)
post #5 of (permalink) Old 12-09-2000, 09:46 AM
good advise. find someone to help you who has done lots bucause if you don't get it right you'll be busting your new gears.
