wood dash-bad idea? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-07-2000, 07:33 PM Thread Starter
wood dash-bad idea?
I need to replace my dash and I am trying to come up with some ideas which are unique and not astronomically expensive. One idea was using some kind of hardwood like walnut and making the dash out of that. Should be easy to work with. I was thinking I would probably back at least part of it with sheetmetal. Anyone tried this or see any obvious problems.
CJay
CJay is offline
post #2 of (permalink) Old 12-07-2000, 07:46 PM
JeepnGreg's Avatar
Re: wood dash-bad idea?
well....wood can warp with heat and moisture ?
Jeep'n Greg
http://members.tripod.com/illinois_OR/index.html
JeepnGreg is offline
post #3 of (permalink) Old 12-07-2000, 07:52 PM
Is this in a CJ... I dont think it would be a great idea
<font color=blue> Muddynut</font color=blue>
<font color=red>[img]/wwwthreads_images/icons/cool.gif[/img]'78 CJ7 "Issues"-304-35s</font color=red>[img]/wwwthreads_images/icons/cool.gif[/img]
post #4 of (permalink) Old 12-07-2000, 09:52 PM
elusive's Avatar
it just wont last. it will also fade and look like poo..and thats before it really gives you trouble.. most of the elctrical system inside the jee is gro8unded to the dash...
~~Elusive~~
tj-7..tellico tested, uwharrie safaried..watch for improvements soon[img]/wwwthreads_images/icons/tongue.gif[/img]..see it at http://www.jeepgod.net
oh yeah, and a 2000 tj, 4.0, dana 44, nv3550
elusive is offline
post #5 of (permalink) Old 12-07-2000, 10:27 PM
Carpal \'Tunnel
If you used the old metal, or a new sheet with cutouts for the electrical and just made a wood overlay with circular sinks in for the gauges and around steering wheel, it could look cool. But you would definitely need the metal behind it.
Thompsons water seal??
Keep Jeepin
Chris
Chris_MJ is offline
post #6 of (permalink) Old 12-07-2000, 11:23 PM Thread Starter
I figured if I got a good, well dried piece of wood then stained and varnished it well it would hold up to the elements. It would probably have to be real thick to stand up to the rigors of driving and I don't want it to look like I nailed a couple of 2x4's to the dash of my jeep. The grounding problem could maybe bypassed but that is a good point. I like the idea of possible using the original dash as a backing. I will have to give it some thought...
thanks
Jay
CJay is offline
post #7 of (permalink) Old 12-07-2000, 11:47 PM
CJay
I did the wood dash thing once. It looked good for about two years, but I had my top off about half that time.
What I used was mahogany veneer about 1/16" thick, I coated both sides with 3 coats polyuathane to protect the wood, then overlayed it onto the dash. The guages and mounting bolts held it in place. I didn't have any problems with grounding anything because I still had the original dash behind the wood.
I think that if you keep it out of the rain and sun as much as possible it will last a lot longer than mine did.
Use wood that will not rot or turn color with moisture like oak.
Keep Jeep-n
Madd Mudder
75 CJ-5, 304, 44 locked 33x12.5 BFG's Wheeling Alaska
post #8 of (permalink) Old 12-08-2000, 02:59 AM
What about termites???
hahahah, seriously, though, i think a wood dash would be too at home in a CJ....maybe in a 2001 Grand cherokee with the color moving map gps......but NOT a trailblazer.....
mike
Give me Jeep or Give me Death!!!
(Will trade functioning organs for CJ-7 or flatfender)
post #9 of (permalink) Old 12-08-2000, 06:53 AM
Teak? Holds up to moisture. Better boat yards have it. might be pricey. Very low maintenance, a little teak oil every now and then. Oak. Shouldn't warp much but will need finishing w/ either polyurethane or a oil finish. ???
JimmyZ is offline
post #10 of (permalink) Old 12-08-2000, 10:40 AM
BHT
One idea that I've had is to use plastic laminate, the stuff they make kitchen counter tops out of. It comes in dozens of patterns and it's pretty cheap. Just cut the gauge holes and glue it to your factory metal dash. Should hold up to the elements as well.
BHT
BHT is offline
