TFI Coil Connector Part #??? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-06-2000, 10:54 PM
Hey Guys,
Anyone have an Autozone or Pep Boys (only things anywhere near me) part number for the TFI coil connector thing?
Thanks A Lot
[b]Boston Mangler
CJ7 With A Bunch Of Goodies
See It At:
http://ct-web.unh.edu/yankeetoys/kspeicher/
post #2 of (permalink) Old 12-06-2000, 10:57 PM
Re: TFI Coil Connector Part #???
sorry
i have a 79 CJ with the stock ignition setup
thanks
[b]Boston Mangler
See It At:
post #3 of (permalink) Old 12-07-2000, 12:35 AM
No, but I can probably have a Standard part number tommorow. They should be able to cross it.
Thanks, Ray
post #4 of (permalink) Old 12-07-2000, 07:01 AM
that might work
thanks
[b]Boston Mangler
See It At:
post #5 of (permalink) Old 12-07-2000, 07:34 AM
Ford 'E-Core' coil ('TFI' Ignition Type),
Standard P/N S-539 (Car Quest)
NAPA P/N ICC-1
Auto Zone doesn't carry that connector, even though it appears in their book.
I don't have a clue about Pep Boys.
Junk Yard Genius is offline
post #6 of (permalink) Old 12-07-2000, 09:30 AM
thanks TR
i just got the NAPA TFI connector, P/N ICC1
but it has 3 wires coming from it
1 wire is red with green stripe
and
2 wires are green with yellow stripe
the 2 green ones attach to the same terminal. is there a wiring diagram for this? I did a seach and found nothing.
thanks man
[b]Boston Mangler
See It At:
post #7 of (permalink) Old 12-07-2000, 10:04 AM
Mangler,
The second wire is for the tachometer signal when used in a Ford. You don't need it and can clip it off if you want to.
'75 CJ5,258 w/Howell EFI,T18a,4.27's,33's,On-board air,Warn 8274
post #8 of (permalink) Old 12-07-2000, 12:06 PM
***** Can i leave it there and hook it up to an Autometer tach?
thanks a lot
[b]Boston Mangler
See It At:
post #9 of (permalink) Old 12-07-2000, 12:47 PM
You can as long as your tachometer is the type that gets its signal from the negative post of the coil. Make sure that side of the connector is the negative side. Look into the coil where the pigtail plugs in and it is labeled there. It's been a while since I looked at one of those coils, but I believe that is the negative side.
post #10 of (permalink) Old 12-07-2000, 07:25 PM
SnowTow is correct.
The extra green wire is for the tach hookup, and on some models, the ignition kill.
Keep it or clip it, the choice is yours....
