Best ignition upgrade - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-06-2000, 05:06 PM
I have a stock ignition on my 1980 258. I was going to replace with a HEI since it is much simpler then the stock wiring which is a mess. However someone told me that this would actually give a weaker spark, and I should do a TR upgrade. Is this true, and how much time and money would ether upgrade take?
post #2 of (permalink) Old 12-06-2000, 08:46 PM
Re: Best ignition upgrade
I've been looking into the same things... Here's a site I've found you may want to read in reference the TR Ignition for the 258.
http://www.users.qwest.net/~ascanlon/
See the tech section on the left...
Good luck...
CJ
Rusty beat-up old junker with many problems.
post #3 of (permalink) Old 12-06-2000, 09:47 PM
Fot get HEI and DO the Teamrush TFI up grade. You and your Jeep will love it. There are those that like HEI and this is only my opinion. TFI is easy and can be done in 30 minutes once you have collected the parts.
post #4 of (permalink) Old 12-07-2000, 01:06 AM
bandhmo-
The TeamRush upgrade can be done for about $50-$60 with very common ignition parts readily available at ANY auto parts store. If you need more info, just let most anyone on here know, you can probably even get part #s. And by the way, many people use the TR upgrade to "upgrade" their HEI.
mike
Give me Jeep or Give me Death!!!
(Will trade functioning organs for CJ-7 or flatfender)
post #5 of (permalink) Old 12-07-2000, 06:59 AM
TR cost Remy Dodge gave of $50 -60 seems a bit low. Below is what I spent not including the MSD upgrade which I later added. From following other posts it looks as though I may not have gotten the best plug wires but they fit well and work fine best I can tell. The basic TR upgrade (if that's what you call it)was perhaps the most improvement for the buck that I have spent. Here is my parts list for my 1980 258.
The parts all came from my local "Car Quest" auto parts but the boxes also say Standard Motor Products Inc. Part numbers should be able to be cross-referenced by your local store. TR has always manitained that you should buy the very best quality parts you can afford.
Coil FD478 $45.67
Rotor FD118X $ 4.77
Cap FD151X $27.99
Cap Adapter FD155 $ 6.99
Pigtail socket S539 $ 12.18
Plug wires 6643 $28.54
Spark plugs (6) Aut945 $6.24
John
post #6 of (permalink) Old 12-07-2000, 07:55 AM
Thanks for the good words guys...
Here is the list for a 258 I-6 from '78 to '90....
And there is a picture attached that shows the difference in the caps and rotors.
For 258 I-6
Cap base or adaptor, 82 Ford F-150 Pickup, with 300 CID I-6, about $5.
Wells (Auto Zone and others) P/N F-960
GP Sorensen (Advance Auto and others) P/N FR-109
Delco P/N F-334
Make sure it's the screw down type, and not the quick clip type.
(Adaptors are attached with screws or quick clips, All the distributor caps are quick clip)
Cap & Rotor, premium, brass terminals, For 86 Ford F-150 Pickup, with 300 CID I-6, about $15.
(Auto Zone) Conrad P/N F-2104-G
(Advanced Auto) Standard Blue Streak P/N KCR-202X
Plug wires, premium store brand, For 86 Ford F-150 Pickup, with 300 CID I-6 WITH E.E.C. for the correct coil wire for the E-core (TFI) coil (spark plug boots on both ends of the coil wire for the E-core 'TFI' style coil),
Without E.E.C. for the correct coil wire for the factory stock can coil, $20 to $50.
Look for spiral core wires if you can find them.
Stay away from solid core wires.
Coil.
For '86 Ford F-150 Pickup, with 300 CID I-6 WITH E.E.C. for the TFI COIL.
(Advanced Auto) GP Sorensen P/N GC-407 S, about $45. Premium Recommended.
(Advanced Auto) GP Sorensen P/N GC-407, about $15. Economy.
(MSD) TFI Premium Coil, P/N 8227, $45.
(NAPA) TFI Premium Coil, P/N IC24, $48.
For '86 Ford F-150 Pickup, with 300 CID I-6 Without E.E.C., CAN COIL
(MSD) Ford Round 'Can' Premium Coil, P/N 8205, $33.
Coil Connectors.
(NAPA) TFI Coil Connector, P/N ICC1, $13.
(Standard Ignition) Motorcraft TFI Coil Connector, P/N S-539 $11.
Junk Yard Genius is offline
post #7 of (permalink) Old 12-07-2000, 10:29 AM
TR... whats the output differences between the Economy Coil and the Premium Coil?
Thanks
<font color=blue> Muddynut</font color=blue>
<font color=red>[img]/wwwthreads_images/icons/cool.gif[/img]'78 CJ7 "Issues"-304-35s</font color=red>[img]/wwwthreads_images/icons/cool.gif[/img]
post #8 of (permalink) Old 12-07-2000, 12:42 PM
This is where I bought my upgrade from....complete kit, everything you need including great instructions....
http://www.driveajeep.com
post #9 of (permalink) Old 12-07-2000, 12:42 PM
The HEI does produce more spark than stock, but less than the TFI (TR) ignition. It is much more expensive and complicated to do. I've done them both. I put HEI onto my '89 Wrangler because I didn't know about the TFI upgrade at the time. Later, I replaced the points ignition in my '74 DJ-5c with a TFI system. There really is no comparison between the two, the TFI is far superior!
Sycho15 is offline
