Weber 32/36 vs. 38 - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-05-2000, 11:03 PM
Weber 32/36 vs. 38
Can you guys give me the pros and cons with regards to the Weber 32/36 vs. the 38. Why choose one vs. the other...
Thanks,...
CJ
Rusty beat-up old junker with many problems.
post #2 of (permalink) Old 12-05-2000, 11:10 PM
JeepnGreg's Avatar
Re: Weber 32/36 vs. 38
the 38 is basically for engines with preformance cams......the 32/36 is what you'll want for a mostly stock 258 or 4.0
i think the 38 would bog down your motor when you gun it
hope that helps....and as always..correct me if im wrong
Jeep'n Greg
http://members.tripod.com/illinois_OR/index.html
JeepnGreg is offline
post #3 of (permalink) Old 12-06-2000, 12:53 AM
Journeyman
The 38 doesn't bog mine down and my engine is pretty much stock.. I've been really satisfied with mine, but I can't tell you how it does compared to a 32/36 because I've never used one.
east116 is offline
post #4 of (permalink) Old 12-06-2000, 07:02 AM
the 32/36 is supposed to be better for crawling and off camber stuff as well. I have a 32/36 but cant compare it to a 38 cause i never had one.
[b]Boston Mangler
CJ7 With A Bunch Of Goodies
See It At:
http://ct-web.unh.edu/yankeetoys/kspeicher/
post #5 of (permalink) Old 12-06-2000, 09:08 AM
Can anyone give me some details about the fuel pressure regulator that is required when using a Weber??? IE where it mounts, the reason for it, where I can find one, and if I really need it, etc. I will be putting the carb on an 87 YJ with a stock I6 except for the TR upgrade. Thanks!
post #6 of (permalink) Old 12-06-2000, 09:45 AM
You will mount the fpr AFTER the filter on the fuel inlet line. You need to run it at about 2.5. Your fuel pump puts out too much pressure for the Weber, plus the use of the fpr helps very much in bumpy or non-level situations, helps keep a constant flow to the float chamber. I've had one for about 2 1/2 years with a 32/36, love it. I think it probably is the closest you can get in performance to fi without going to fi.
Brad
ORC Land Use Section Editor
http://www.off-road.com/land
post #7 of (permalink) Old 12-06-2000, 09:55 AM
Thanks for the info guys, that really helped!
post #8 of (permalink) Old 12-06-2000, 12:52 PM
Thanks for the input guys... I had found the Weber Carb web site, and read about them... Looks like the only difference is the 38 gives better acceleration, and power (also cost about $20-$30 more). Less mpg improvements vs. the 32/36. I'll find the web address and repost it... Seemed to have misplaced it right now...
Weber tech guy says, fp reg should be used if fuel pressure is above 3 psi in the vehicle..
CJ
post #9 of (permalink) Old 12-06-2000, 12:57 PM
One thing about the 38, seems most complaints I've heard about bogging are with the 38 on a stock motor. It is just a little too much carb. And as far as the fuel pressure of your stock pump, I believe it will be about 7-8 lbs., I seem to remember that range from when I checked mine before installing the Weber.
Brad
post #10 of (permalink) Old 12-06-2000, 08:35 PM
Follow up note, here's Weber's site, you can read on your own:
http://www.webercarburetors.com/
Thanks again for all the feedback
CJ
