Putting lift on -- can't get a bolt out - HELP! - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-01-2000, 07:07 PM
Putting lift on -- can\'t get a bolt out - HELP!
My Jeep is torn apart, because I'm putting on my new leaf springs, and I can't get the back pivot bolt out of the old leaf spring! I've beat on it, heated it, and even tried to turn it, but it's stuck in the rubber bushing of the spring good. This is the bolt on the non shackle end.
How did anyone else get these bolts out? So far all the others have come out fine. . .
Thanks,
Jed Smith
'80 Jeep CJ7, I-6 258.
4" lift in the works
post #2 of (permalink) Old 12-01-2000, 07:30 PM
Re: Putting lift on -- can\'t get a bolt out - HELP!
a c clamp and small socket to push it out?
a hammer and a punch?
worst case you might have to drill a bunch of littl eholes aorund hte rubber to loosten it up a little.
OzarkJeep
"They throw the best damn parties at the Rim of Hell"
ozarkjeep is offline
post #3 of (permalink) Old 12-01-2000, 07:35 PM
jed, when i did mine i sprayed the hell out of them withlots of liquid wrench and had a friend of mine turn one end as i hit the other with a bfh. and they finally came losebut it still was not easy but keep spraying them as you go. keep jeepin gary
95 yj black. 4.0L .5.5 sup. lift 3 inch body lift 36x12.50 swampers, safri rackon top for my women.
post #4 of (permalink) Old 12-01-2000, 07:59 PM
I used an air cutoff tool to zip through the bolt on both sides, just inside the hanger. Then bought new Grade 8 bolts and locknuts at hardware store. This after hours of various techniques, including pounding on them with full size sledge. This was on my front (rear hanger) springs. The rear ones came right out with a tap of a hammer. Go figure.
Max
dealing with your Jeep obsession;
the steps - recognition
denial
acceptance?
uhh...screw it, lets go wheelin'
CJ money pit is offline
post #5 of (permalink) Old 12-01-2000, 08:07 PM
Yep, their a bugger... here's how I removed those bolts...
1. Sawed off both ends of the bolt.
2. Used a propane torch to heat the bolt. Put the flame directly on the bolt... you can put the bushing's flame out later.
3. Using another long bolt, or punch, while the bolt is hot, use the bolt or puch to drive out the stubborn bolt.
4. Stick a hacksaw blade into the remains and saw it in half.
Using a flat blade screw driver, remove one quarter of the bushing at a time by pulling it out. Just stab on piece and leverage it out.
Easy as pie.
Happy Holidays and Safe Jeepin'
Larry
post #6 of (permalink) Old 12-01-2000, 08:11 PM
Air cut-off tool like CJ money pit. Makes pretty short work of them and you barely even have to exert yourself.
Jeepskate is offline
post #7 of (permalink) Old 12-01-2000, 08:33 PM
Mel85CJ's Avatar
Sawzall, just inside the hangars was how we did it on one jeep, another we had trouble, I wrenched on it to make it spin while another person hit it with a sledge.
Mel85CJ is offline
post #8 of (permalink) Old 12-01-2000, 09:18 PM
I Do This For The Glory
JEEPN's Avatar
Mine did the same thing. I used PB Blaster, and a screwdriver. I worked the screwdriver in between the bushing and spring, then hit it with the PB to keep it loose. I also used a BFH and a center punch, beat the snot out of it. It came loose and I was able to re-use the bushing. When you install the new ones, lube them up with some Anti-Seize, or better yet, some synthetic grease, they'll come out easy next time.
JEEPN
Winter Harbor, Maine
'81 CJ-8 Scrambled!
JEEPN is offline
post #9 of (permalink) Old 12-01-2000, 09:34 PM
SonoraBob's Avatar
To me, the answer is clear. You need a bigger hammer!!!
CJ-8, 4.0, NP435, D44 x D60, ARB's, 4w Disc, 2"YJ springs, SOA, 1" Body lift, 35" TSL SX
CJ-6, Cherokee
SonoraBob is offline
post #10 of (permalink) Old 12-01-2000, 09:59 PM
elusive's Avatar
bigger hammer allways works for me.. but i did hit a couple so hard I bent the solid shackle hanger. be carefull too.. I have had 2 of them let loose and really fly across the shop. I like the bolt cutting suggestions
~~Elusive~~
tj-7..tellico tested, uwharrie safaried..watch for improvements soon[img]/wwwthreads_images/icons/tongue.gif[/img]..see it at http://www.jeepgod.net
oh yeah, and a 2000 tj, 4.0, dana 44, nv3550
elusive is offline
