Quick question about fuel injectors - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-01-2000, 04:59 PM
My Holley Projection seems to be running way to rich. I checked the injectors with a timing light and you could see lots of droplets of fuel in the mist. Are throttle body injectors supposed to be a fine mist? I seem to remember reading somwhere that they weren't.
Thanks,
jeff
post #2 of (permalink) Old 12-01-2000, 05:13 PM
Official Historian
WILL's Avatar
Re: Quick question about fuel injectors
mine spray a fine conical mist. i did have both go bad and stop working but they were replaced under warranty. i have my choke set about 1/4, accel all the way lean, main, idle and high about 1/2.
79/CJ-7/AMC360/TH400/Q-TRAC/d30/d44/33's/RS9000s/Herculiner/Pro-jection 2D/MSD/4.10s/lockrights
WILL is offline
post #3 of (permalink) Old 12-01-2000, 08:23 PM
Yes, you're correct... the injector should deliver the fuel in a spray pattern. Go to you auto parts store and see about getting a rebuild kit or a replacement. Often you can just take them apart, clean, burnish and reassemble them and have 'em work fine.
Look at the pintle. If it's got deposits on it, it may not be closing properly. That's a fuel leak. The screen behind the injector may also be clogged from deposits and may be needing a good cleaning. When the pintle opens and the fuel starts to spurt out in dropplets... something'w wrong, it should be a defined spray pattern.
Happy Holidays and Safe Jeepin'
Larry
