dodge tranny leaking please read me!! - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-30-2000, 10:16 PM
any of you dodge guys know why my tranny is running fluid out of the bell housing???? I just had it rebuilt and we were filling it for the first time and if started over flowing on the 8 or 9th quart. We didnt have it running at the time does that matter??? Its a dodge 727 behind a 360 thanks for the help
The baddest four letter word JEEP
post #2 of (permalink) Old 12-01-2000, 06:21 AM
Re: dodge tranny leaking please read me!!
If the fluid is running out of the bell housing area the posibilities are:
1. Transmission case to Pump housing gasket failing.
2. Troque Converter to Reactor Shaft bushing/seals failing.
3. A bolt left out of the Pump housing.
4. Improper bolt torquing of the Pump housing.
5. Overfill of the transmission. Put in about 4 quarts of ATF, then run the transmission. The Torque converter will start to fill, as will the valve body. Then work through the gears and keep filling untill you reach the full mark on the dip stick.
6. Make sure it's dripping from inside the bell housing and not somewhere else like the pan being impropperly torqued.
Were I a bettin' man, I'd bet you completley filled the inside of the case of the transmission... and nothing yet has gone into the converter of the valve body. So.... the fluid level reaches the vent in the pump housing and starts to travel from the inside of the transmission thorugh the vent and down between the torque converter and the transmission case down the case to the outside...
Start the engine and draw that stuff into the conveter and valve body... I'd bet you'll not have a leak after that...
Happy Holidays and Safe Jeepin'
Larry
post #3 of (permalink) Old 12-01-2000, 08:15 AM
Matt M38A1
FYI- If you also have a cooler in there for the tranny and you didn't empty it, there will be a few quarts hiding in there as well. This will add to your overfill issue.
post #4 of (permalink) Old 12-01-2000, 04:14 PM
if it were a used tranny id guess pump bushing and seal are bad, the converter nozzle sticks thru them, ive seen teh bushing go bad and take the nozzle and seal with it ( hopefully not a new one though!)
Leve most likely has it, the vent is right in there also, so its probably just over filled, but MAN itll have to be VERY full to reach the vent?
you need to start it and check the level.
OzarkJeep
"They throw the best damn parties at the Rim of Hell"
ozarkjeep is offline
post #5 of (permalink) Old 12-01-2000, 04:54 PM
Thanks guys i figured thats what it was but i didn't know for sure I looked and couldn't find a vent on itso i figured it was in the bell housing. we had a junk battery and couldent start it last night. Any one know how much these hold dry? I think 11 qts just making sure. There was 9 in when it started leaking last night Leve you always have the answeres thanks every one fore the help.
post #6 of (permalink) Old 12-01-2000, 08:53 PM
Heres a thought, Torque converter drain plug? It cost me $30.00 at a shop when I was 17 to have a similar leak fixed they just tightened the plug. Now if they had done it for free, I would have been a customer for life (they would have made a fortune by now)
Only One Jeep left but its got a 4" Superlift and 33" BFG AT'S
Talk's! Cheap Join the NRA!
http://www.nrahq.org
post #7 of (permalink) Old 12-01-2000, 09:51 PM
most Tflight converters ive seen dont have a drainplug.
but its always a possibility!
OzarkJeep
