360 Intake? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 10-16-2000, 12:28 AM
360 Intake?
I.ve got a chance to pick up a 360 4 barrel intake real cheap, how are the stock intakes, good, bad, do they produce good low RPM numbers? It also will have a stock carb on it, I think a motarola, is it worth keeping?
Another thing, do the Jeep AC compressors make good air pumps? As you might of gested, I can get my hands one of those cheap to.
Keep Jeep-n
Madd Mudder
post #2 of (permalink) Old 10-16-2000, 06:18 AM
elusive's Avatar
Re: 360 Intake?
simply...
yes, the stock 4bbl intake and carb are worth bolting on
yes, the jeep compressor is a york, the best kind for on board air
~~Elusive~~
tj-7..tellico tested, uwharrie safaried, [img]/wwwthreads_images/icons/tongue.gif[/img]..see it at http://www.jeepgod.net
oh yeah, and a 2000 tj, 4.0, dana 44, nv3550
elusive is offline
post #3 of (permalink) Old 10-16-2000, 06:32 AM
Re: 360 Intake?
Id loose the motorcraft carb in favor of something alittle more holley or Qjet-ish.
if the AC compressor is off of an older Jeep itll be great for air, but if its off of a newer Jeep its a differrent kind.
if it looks like a little horizontal shaft Go cart engine then its most likely a YORK.
if it looks like an electric motor then its a non sump type, and not quite as good for air pumping.
good luck
OzarkJeep
"If I take a stand It will be my own"
ozarkjeep is offline
post #4 of (permalink) Old 10-17-2000, 02:04 AM
Re: 360 Intake?
wsmiller, if that stock intake is for a 4 barrel Motorcraft spreadbore carb like the one sitting in my basement, here`s a few things I found out about them. The Motorcraft spreadbore uses the standard Motorcraft/Holley bolt pattern, so a Holley 4 barrel will work on one of these I think, how good it would work I don`t know. The throttle bore size and spacing is similar in appearance to a Qjet or Thermoquad, but only in appearance. The Qjet or Thermoquad will not bolt directly to one of these intakes. I`ve been told by Parts Mike and others the Motorcraft spreadbore carb is a pretty crappy carb, especially off-road, and is hard to get tuned. I did install a Qjet on the intake I have but I had to make an adapter plate using a Qjet to Holley carb adapter. I don`t have it installed yet but am planning on finding out how good this is going to work in the next few weeks.
Jeff
<font color=red>`75 CJ-5,304,T-18/D300,</font color=red>
<font color=white>SOA w/YJ springs,D30/D44,</font color=white>
<font color=blue>Always under construction</font color=blue>
Jeff is offline
