What do I use for my Trans Cooler hose? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 10-10-2000, 03:29 PM
I am getting ready to get what I need to run the lines from the trans to the cooler which is built into the radiator. What kind of lines do i need? Can I use rubber lines or do I use copper? or what?
Its a TH400/ what size lines do I need also? Thanks.
1997 TJ w/ 33's
1984 CJ7 V8 SOA w/35's or 39's
http://members.aol.com/a4x4jeeper/
www.jeepeast.com/overmost
post #2 of (permalink) Old 10-10-2000, 03:36 PM
Re: What do I use for my Trans Cooler hose?
Not sure which lines you are working on but my stock Th400 has steel hard lines attached to the trans and then tie into the cooler with flexible rubber lines. I could not find a replacement for on that leaked so I just put the fittings into a larger diameter piece of rubber transmission line and secured them with hose clamps. It has worked for the last 2 years. Not sure if this answers your question but I tried.
rich
77cj7304qtracTH400
fratt
fratt77CJ7 is offline
post #3 of (permalink) Old 10-10-2000, 03:48 PM
Generaly, cooler lines are 3/8" brake lines with inverted flare fittings. If you need to have hoses they shoud be rated for at least 150 PSI.
good luck, jjc
post #4 of (permalink) Old 10-10-2000, 06:43 PM
Dont use fuel line or vaccum hose.oils tend to soften rubber lines.Most any decent parts store can help you out.If connecting to steel lines,dont forget to flare the end,and double clamp.
Matt
all laws only affect the law abiding
support capital punishment,guarantee no repeat offenders
post #5 of (permalink) Old 10-10-2000, 11:22 PM
Gates has some hose. It is called lock-on hydraulic hose, rated for 300 PSI. The neat thing about it is you don't use hose clamps, just a special hose end that you push in. the only way that end will come off is if you cut it off. My recomendation is steel brake line, just like most of OEM does.
Thanks, Ray
