Re: Looking for the bushings for shift linkage
Go hydraulic!!
I had the same proble for years until I went to a hydraulic set-up. You can use the set up off an 80-86 CJ, or get a Wilwood unit like I did and make a custom bracket for it. For the Wilwood unit, I got it from a race product outlet ($79.00 for master unit and slave cylinder)you need to look in the back of Circle Track, NASCAR magizine, or Sumit Racing sells them also(for a little more $).
If you want to remain stock, call Four Wheel Drive Hardware at 1-800-333-5535 they sell the bushings for a buck or two.
Good Luck
Madd Mudder
