Re: 82cj-7amc20 reinstall axle
Did you get the bearing pressed on all the way? The inner race has to be pushed up to the shoulder on the axle. You would need access to a 5 or 10 ton press to do this. If not the axle will stick out and you won't be able to bolt up the flange seal to the axle flange. If you have any more details or a pic send them, that would help.
Steve M
1976 CJ-7, 304, TH400, Q-Trac, 4:10's, 33x12.5 Goodyear MT's, rotten floorboards, cheesy aluminum tub overlay, you get the idea....
"Heavy guns - Reach out and touch someone"
