Re: Evap canister
[img]/wwwthreads_images/icons/blush.gif[/img] Everything that I know about emmissions I learned from CJ-8/5.2Mag.....[img]/wwwthreads_images/icons/blush.gif[/img] Marty was a valuable source of good information when we re-smogged our illegal, smogless, hot-rod CJ 304 V8. As I understand it, the charcoal in the cannister captures the fumes from the pool of gasoline in the fuel tank and from the pool of gasoline in the carburetor when your Jeep is sitting there not running and especially when the heat soak from a hard run is warming up the carb and the fuel tank now that the breeze from driving has stopped, and the heat is causing the gasoline to overheat and "gas off" like crazy. The fumes from the two pools of gasoline accumulate in the charcoal pack, and therefore don't fill up the garage and annoy your Jeepchick. ["Owwwww.....your Jeep STINKS!"[img]/wwwthreads_images/icons/mad.gif[/img]] When the engine is restarted, the purge valve receives a signal from the vacuum advance line, and that lifts the valve seat and allows intake manifold vacuum from the engine to suck the accumulated fumes out of the charcoal pack, mix them with the intake mixture, and make everybody oh so happy once again.[img]/wwwthreads_images/icons/smile.gif[/img] So you can see, that the cannister does not retard performance and is actually a benefit. THERE IS ONE CAUTION......cannisters CAN cough up charcoal into the vacuum system, so a fuel filter in the purge line is a darn good insurance policy. A clear filter would even be better so you can SEE if it is happening.[img]/wwwthreads_images/icons/smile.gif[/img]Oops!..[img]/wwwthreads_images/icons/blush.gif[/img]....that should have been a fuel filter in the CARB BOWL VENT LINE......not the purge line.[img]/wwwthreads_images/icons/blush.gif[/img] The idea was to keep charcoal out of the carb bowl.[img]/wwwthreads_images/icons/crazy.gif[/img]
CJDave
