Qustion on pulleys
Question is, i have a V belt pulley 6 inches in diameter(power pulley), and it turns another pulley 8 inches in diameter (accessory),if mid way between these two pulleys, i add a double (pancaked together) set of pulleys, and then have the first, 6 inch pulley turning a 8 inch, the 8 inch will turn the pancaked pulley that will be 3 inches in diameter and then it in turn runs the original 8 inch pulley, wont that multiply power to the last 8 inch and also slow its rotational speed?
