You can buy new ring gears from FWDHardware.
Most machine shops can press the new one on.
There was a very good 'starter' thread here recently.
As follows ..........
------------- cut
Subject Re: How critical is it to shim your starter? Posted by TeamRush (veteran) Posted on 8/25/00 03:13 PM From IP 208.143.14.62
An old GM engineer once gave the secret of GM starters...
An 1/8" drill bit between starter and flywheel.
No More, No Less. It's worked for me for over 20 years...
Subject Re: How critical is it to shim your starter? Posted by Matt1911 (newbie) Posted on 8/25/00 03:24 PM From IP 63.38.144.173
Teamrush nailed it.but thats sometimes hard to do layin' in the drive way.Get a coulpe of each shim(thick and thin),start with a thin and listen,shims are cheap,and you will use them someday.seems like a pain i know,but its a lot faster than changing a flywheel
all laws only affect the law abiding
support capital punishment,guarantee no repeat offenders
Subject Re: How critical is it to shim your starter? Posted by CJDave (Carpal Tunnel) Posted on 8/25/00 04:20 PM From IP 208.12.101.58
Oh.....and one other thing....only use the GENUINE knurled O.D. GM starter bolts.
CJDave
Quadra-Tracs modified While-U-Wait by the crack moonguy Quadra-Trac Team.
Subject Re: How critical is it to shim your starter? Posted by TeamRush (veteran) Posted on 8/25/00 04:26 PM From IP 208.143.14.62
I'm so amazed at how may people that have been turning wrenches for YEARS and don't know that.
Most of the chevy guys don't even know that...
It's too easy.
I have a selection of different 1/8" wires bent into strange shapes to get to the clearance...
1/8" from starter drive gear shaft to the flywheel teeth, and all your problems go away.
In 25 years I've never seen that fail to work...
Works on the V-6 starters too.
Subject Re: How critical is it to shim your starter? Posted by CJDave (Carpal Tunnel) Posted on 8/25/00 04:41 PM From IP 208.12.101.58
Are you saying that the wire goes IN the bottom of the tooth groove of the flywheel and the starter tooth is held that distance away? Is that how this works?
CJDave
Subject Re: How critical is it to shim your starter? Posted by TeamRush (veteran) Posted on 8/25/00 05:04 PM From IP 208.143.14.62
Nope,
Point a tooth directly at the starter drive spindle shaft.
Going with the flywheel/ flexplate, you want the drill rod to just slip in between the tooth and the shaft.
The starter drive gear will be back out of the way, so only the shaft it slides on is out that far.
Go with the flywheel teeth, and against (cross 'T') the starter drive gear spindle shaft.
Exactly 1/8" is what you are shooting for.
If the dust cover comes off in the right place, this isn't hard.
If it's way up in a bell housing somewhere, it's a B*TCH! With a capitol "B"!!
Subject Re: How critical is it to shim your starter? Posted by CJDave (Carpal Tunnel) Posted on 8/25/00 06:18 PM From IP 208.12.101.8
Ahh......I see it now. Boy...it's hard to believe that the root diameter of the drive gear is so small. 1/8" is not all that much. So you shim or de-shim to get the 1/8" rod to fit up close. That's not too hard. I have NEVER heard of this little technique.
CJDave
JAF
