wierd clutch noise - need help. - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-28-2000, 04:52 AM
jeepfreak
Im having a problem with my 81 cj5 that it cant figure out so I thought i'de see what you guys thought. When I press the clutch it makes a grinding noise. I figured it was the throw out bearing so I droped the tranny and xfer case and installed a new one. while I was in there I instpected the clutch and clutch plate(which are only three months old) through the back of the bell housing. They looked fine. I got everything back together started it up pressed the clutch and it made the same noise. What else could this noise be??? It seemed to have happend after wheeling on a difficult trail.
JACOB
81 cj5 WITH SOA/SR/302
2000 TJ
Confuscious said:
"The wise man takes the path of least resistance"
I say:
"Confucious didn't know jack about Jeeps"
post #2 of (permalink) Old 09-28-2000, 06:28 AM
Re: wierd clutch noise - need help.
Could be you dinged the pilot bearing when you put the tranny in, or the parts guys gave you the wrong size - I didn't try the new pilot bearing on the input shaft of the tranny when I changed the Iron Duke in my CJ, and every time I push in the clutch now it grinds. For me, it's easier to pull the motor to do a clutch than drop the tranny and transfer case (that's probably the only advantage of the four-cylinder[img]/wwwthreads_images/icons/smile.gif[/img]!).
Bob N
"Think your new truck is better, let's go wheeling and see"
post #3 of (permalink) Old 09-28-2000, 03:42 PM
jeepfreak
Hmm that might be it...I never cahnged the pilot bearing. What is the procedure for getting them out?
JACOB
2000 TJ
I say:
post #4 of (permalink) Old 09-28-2000, 05:02 PM
I use a slide hammer. The other way I have seen it done is to pack the center of the bushing with grease then pound a rod the same size as the hole into the hole and let the grease push the bearing out.
Good Luck
Kriss
post #5 of (permalink) Old 09-29-2000, 09:16 AM
Robert87yj
Another thought, though the pilot bearing sounds like the culprit. You might have maximized your tolerances. Is it a scratchy noise?
Robert87yj[img]/wwwthreads_images/icons/tongue.gif[/img]
4.2 w/<font color=blue>(4.0 head & MPI)</font color=blue>
Process of a moonguy after beer
[img]/wwwthreads_images/icons/mad.gif[/img] [img]/wwwthreads_images/icons/frown.gif[/img] [img]/wwwthreads_images/icons/crazy.gif[/img] [img]/wwwthreads_images/icons/wink.gif[/img] [img]/wwwthreads_images/icons/smile.gif[/img] [img]/wwwthreads_images/icons/blush.gif[/img]
post #6 of (permalink) Old 09-29-2000, 01:39 PM
Same thing happened to me and it was the pilot bushing. Hope this helps
