Tie to Frame project - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-26-2000, 04:53 PM
The kit calls for total of 6 points tied to frame. I have completed the 2 front tie to frame gussets and now have started the rear portion. It calls for using two 2" pre-bent pipes and running them from the top(inside) of the fender well to the frame on each side. Well easier said than done...I have attached the first of the rear tie to pipes, which run from the front inside of the fender well to the frame,just infront of the rear shock mount. Now the problem..I cannot figure out where to run the second rear pipe. I have two options: I either weld the support tubing to the bumper brace (1/4"x 2") this would make it nearly impossible to remove the bracing without torching. The other option is to run the tubing from the top of the fenderwell down to the bumper and secure it to the bumper??? This would or could create compounding affects if the bumper was bent inward or outward.
Attaching the tubing to the bumper brace very near the frame, would probably have less ramifications if the bumper was hit.
Any comments, suggestions.
Thanks.
Everyday travel is off-roading in this town....
post #2 of (permalink) Old 09-26-2000, 11:10 PM
Re: Tie to Frame project
On Alec78CJ's 78 C-7, FlMudCJ welded the bent pipe directly to the side of the framerail alongside the bumper mount. He has no problems and we dont expect any, and George put a full bead around that pipe...its not going ANYWHERE!
mikey
If you cant DODGE it, JEEP it!
post #3 of (permalink) Old 09-27-2000, 02:23 PM
Some pictures so far of the rear tie to frame. Im now building a rear bumper before I attach the last two tie to frame tubes.
post #4 of (permalink) Old 09-27-2000, 02:26 PM
another pict, dont look to close at that bead[img]/wwwthreads_images/icons/laugh.gif[/img]
post #5 of (permalink) Old 09-27-2000, 02:29 PM
yet another.....
post #6 of (permalink) Old 09-27-2000, 02:37 PM
Is tire clearance at full articulation gonna be OK?
Brad
ORC Land Use Section Editor
http://www.off-road.com/land
post #7 of (permalink) Old 09-27-2000, 02:51 PM
Im sure hoping so! In real life it looks as though I'll have plenty of clearance, then I only have 31" tires right now but eventually will go with larger ones..it could be a problem then. I guess if it is I'll go with SOA or 4" lift.
