Re: Radios Installs
Your CB must have a front mic hookup. I saw a TJ that had a pretty nice setup. The guy took out the factory AM/FM whatever and put in an aftermarket am/fm/cd player. Since the factory opening was so large he mounted his "little" CB on top of his radio and used the extra pieces from the mounting kit to cover the excess holes. He also ran an external speaker. If your CB has a side mic hookup than you could drill a hole in your Tuffy, take apart your mike, run the wire through the hole with a grommet for waterproofing, and then rewire the mike. Hope you understood that. [img]/wwwthreads_images/icons/smile.gif[/img]
I may not like what you say, but I'll defend to the death your right to say it.
Semper Jeep
