CJ-7 swaying all over - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-26-2000, 09:29 AM Thread Starter
My '84 CJ is starting to scare the crap out of me on the highway. The front-end is tight, the axle bearings are tourqued to specs, the ball joints are good, the steering stabilizer is good, and the alignment is good. The steering box, pump, and shaft are original. I have 31x10.5's and a 2.5" lift in it. I'm basically constantly steering or counter-steering to keep it in the lines. Could it be the steering box?
Paddy Whacker is offline
post #2 of (permalink) Old 09-26-2000, 10:35 AM
Re: CJ-7 swaying all over
Shackles are a common cause of wandering. Do you have lift shackels? Are they loose?
canis
'82 CJ-7/360/727/D300/M.O.R.E. shackles and lots of ideas!
Have you kissed your JEEP lately?
post #3 of (permalink) Old 09-26-2000, 10:42 AM
When you say the alignment is good, are you referring to the toe-in or did you have the full frontend alignment checked? What you've described is a classic symptom of insufficient caster. If you have longer shackles, they roll the axle down in the front and reduce the caster. You might try some degree shims to rotate the axle back and see what happens. Toe out can contribute to wandering, too.
Good Luck!
Jason '87YJ
"If you didn't build it, it isn't yours . . ."
post #4 of (permalink) Old 09-26-2000, 11:02 AM
JeepnGreg's Avatar
check the sway bar and all the suspension bushings...if they are stock ones...try replacing them with polyurethane......i have the swaying problem too but i have really big liftshackles on my '7.
hope that helps
Jeep'n Greg
1985 CJ7, 258, t-5, d-300,
2000 TJ 4.0L, jamboree edition
JeepnGreg is offline
post #5 of (permalink) Old 09-26-2000, 12:59 PM
I Do This For The Glory
JEEPN's Avatar
It does sound like a caster problem to me as well. Did it just become noticeable after the lift or has it just occurred out of the blue?
JEEPN
'81 CJ-8 Scrambled!
GM151/SM465/NP205 twinstick/7" Lift/33" Swampers/REP 8000/RS9000's/Scout II D44's F&R w/4.10's & Lockrights
JEEPN is offline
post #6 of (permalink) Old 09-26-2000, 02:14 PM Thread Starter
The shackles are stock, and the bushings look good (Came with the lift). I haven't done anything to the suspension on the Jeep, i bought it as is and put about 20k on it. It started swaying noticably over the summer. Almost feels like one of the rear tires are low on air.
post #7 of (permalink) Old 09-26-2000, 02:20 PM
Pitman Arm....
89YJ/LT1/NV4500/5.25"Lft
"Those damned replicants. Have u retired any today?"
post #8 of (permalink) Old 09-26-2000, 02:36 PM
Have you checked the U-bolts?
Thanks, Ray
post #9 of (permalink) Old 09-26-2000, 03:16 PM
JEEPN's Avatar
Check the steering box. They get worn in the middle and tend to wander. To check this, look at the front tires while in the jeep. Now slowly move the steering wheel back and forth and make a note of it's position when the tires start to move. If it moves more than 1/8" turn in each direction without moving the tires, it needs to be tightened. The center of the gears get worn out and pick up some slop, then you have to constantly correct to keep it straight down the road. My '78 Scout II does this, it's hard to drive, only does it going straight, but you get used to it after awhile (until you hit the brakes and it sends you all over the road again). Check these few items and get back to us, I know I'm curious as to what it could be.
JEEPN
'81 CJ-8 Scrambled!
JEEPN is offline
post #10 of (permalink) Old 09-26-2000, 04:34 PM Thread Starter
JEEPN-
How much and how do i tighten the gear box? I know it has some play, on the road i can swing the wheel back and forth some and it stays straight.
