front disc brakes - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-17-2000, 08:41 AM
front disc brakes
I was repacking my wheel bearings the other day and noticed something strange. The inside pad(the one on the piston side of the caliper)is wearing a lot faster than the outside pad. Does this mean that i'm going to have to get my calipers rebuilt or replaced, or is it something else maybe? any info is greatly apreciated.
Thanks,James
82cj7,258,np435,weber,hei,rhino lining
post #2 of (permalink) Old 09-17-2000, 08:53 AM
Re: front disc brakes
I think that is normal ....check it against the other side see if the same wear pattern is happening
Ray
unhumen is offline
post #3 of (permalink) Old 09-17-2000, 09:00 AM
If it's normal, should I just periodically swap the pads from one side to the other so as to have equal wear between them?
post #4 of (permalink) Old 09-17-2000, 09:36 PM
Ray, if i'm not mistaken, and i very well may be....excessive wear on the inside pad indicates that your caliper may not be releasing properly....that the piston is not retracting as it should be....i think....and no, its not a good idea to swap brake parts...they're cheap enough. Get new parts and fix the old problem. best advice i can give ya! good luck
mikey
If you cant DODGE it, JEEP it!
post #5 of (permalink) Old 09-18-2000, 11:53 AM
You might want to check the caliper slides and grease and/or replace them. You can buy the hardware kit which includes the boots and the plastic insert at autozone.
Lugnut 77 cj5
lugnut is offline
post #6 of (permalink) Old 09-18-2000, 12:10 PM
I Do This For The Glory
JEEPN's Avatar
My '95 Trooper has this problem in the rear. At $250 for the caliper, I'll tear it down every 10,000 miles and lube it up again, then swap pads. Been doing this for 40,000 miles, no problems.
JEEPN
'81 CJ-8 Scrambled!
GM151/SM465/NP205 twinstick/7" Lift/33" Swampers/REP 8000/RS9000's/Scout II D44's F&R w/4.10's & Lockrights
JEEPN is offline
post #7 of (permalink) Old 09-18-2000, 12:38 PM
Official Historian
WILL's Avatar
if one pad on a caliper is wearing faster than the other pad, it would suggest the caliper is not moving. sounds like the slides need to be greased so the caliper can put equal pressure on both pads.
79/CJ-7/AMC360/TH400/Q-TRAC/d30/d44/33's/RS9000s/Herculiner/Pro-jection 2D/MSD/4.10s/lockrights
WILL is offline
post #8 of (permalink) Old 09-19-2000, 08:19 AM
thanks for all the input. I was planning on trying to investigate that some more today after I get back from the alignment shop. Gotta make sure my toe-in is correct, tires are too darn expensive for abnormal wear to go unchecked.
later,James
post #9 of (permalink) Old 09-19-2000, 10:17 PM
Use the ford silicon brake grease(not wheel bearing grease)lube the slides,and where the caliper meets the knuckle(clean the rust off best you can),you'll probably go a long time with no problems.
all laws only affect the law abiding
support capital punishment,guarantee no repeat offenders
