Electric Motor question...Starter/winch motor? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-16-2000, 10:00 PM
Well, I'm in the process of rebuilding a Ramsey RE 8000...It is in need of some new solenoids and a new electric motor...Called around a bit, and I'll probably just use two continuous hold solenoids and engineer an underhood mount for them instead of replacing the factory solenoids...but that electric motor...Ramsey now makes a 4.8hp motor to replace the original one, but they want $225 for it. The motor looks just like a starter motor. It's got 3 posts (1 ground, one forward rotation, one reverse rotation) and the shaft end has 4 ears, at 90 degree intervals, for mounting. The shaft is about 3/4" diameter, with one 1/8" tongue sticking out of it to drive the gear. Does anyone know if it is a starter motor? Or, does anyone know the HP developed by a starter motor? Are starter motors series wound or permanent magnet? Who thinks one would work/last in a winching application? From what I gather, the winch originally had a 1.8hp motor. An old firefighter friend of mine said that they had a fireengine with an old worm drive winch on it that just used a Ford starter motor for its power. Any thoughts? A $50 starter sounds much better than a $225 "winch motor".
Currently looking for corporate sponsors for jeep improvements...will sell advertising space on jeep, will also sell soul/body...make an offer.
post #2 of (permalink) Old 09-16-2000, 10:09 PM
Re: Electric Motor question...Starter/winch motor?
it is designed the same as a starter motor but it is different. you can just have the motor rebuilt. i just had mine done and it was around $75.
brian wilson
80 cj5 "high 5"
stretched to 100" wb
351w/np435/d300/d44/d60/detroits/4.56/35ss/bdlocks
post #3 of (permalink) Old 09-17-2000, 11:10 AM
mindbender
Farm Jeep: Just a question about the motors. I have a RE:8000 that needs rebuilt. What, if any performance changes will the 4+ hp motor give to the RE, compared to the 1+ hp motor that is on it? For example, does it change overall rating - or retrival speed? The other thought I had was to find out if the original motor can be rewound to stronger specs.
HiFive: Where did you have your motor rebuilt?
Thanks,
Mindbender 85CJ7 I258 [img]/wwwthreads_images/icons/smile.gif[/img] 40 head ported polished [img]/wwwthreads_images/icons/smile.gif[/img]
Jacobs [img]/wwwthreads_images/icons/smile.gif[/img] 31" [img]/wwwthreads_images/icons/smile.gif[/img] 999 insulated hard top
post #4 of (permalink) Old 09-17-2000, 12:42 PM
I don't really know the answer to that question...I've been kinda wondering too...I imagine that a motor with twice the HP would, even if it doesn't have a higher max RPM, run at a higher RPM under load, increasing the line speed...even though the worm drive still won't go challenging an 8274 anytime soon.
post #5 of (permalink) Old 09-17-2000, 03:02 PM
i just took it to an electric motor maintenance shop. they sell and rebuild all types of electric motors and pumps.
brian wilson
80 cj5 "high 5"
