does this exist?? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-15-2000, 12:45 PM
does this exist??
I want to run 35x12.5x15 tires on one of my Jeeps. I also want to swap in some 3/4 ton chevy axles that I have. My question is can I use a 15 inch tire/wheel with those axles? I know those rear drums are huge, but I would convert to disc if the 15's would work, or I might convert to disc anyway. Are there many choices out there for 15" wheels with an eight lug pattern? I have not seen many, if any.
Dan
post #2 of (permalink) Old 09-15-2000, 01:26 PM
Re: does this exist??
I'm running 15x8's on my GM 3/4 ton axles. I got the 8 lug wheels at Discount tire, but every place I called had them. They're chrome spokes and cost about $38 each. 4 inch backspacing and 2.5 inch were the choices along with white or chrome. I went with the 4 inch backspacing because I wanted to keep the scrub radius as small as possible and I didn't like the whole Jeep sitting on the (admittedly large) outboard end of the spindle. I had to do quite a bit of grinding on the front calipers to fit them. 3.5" BS would have worked better.
I have not found an aluminum 15" 8-lug rim yet. I think it would have too thick of a wall and would require more grinding yet.
Jason '87YJ
"If you didn't build it, it isn't yours . . ."
post #3 of (permalink) Old 09-15-2000, 01:28 PM
yes you should be able to run the 3/4 ton axles and 15" rims. the 1ton dana 60 is where you run into trouble with the 15" rims. you also shouldn't have any problems finding rims either. look around and ask around and if you can't find any check with stockton wheel. they have a web address but i don't know it so just look for it on a search engine like yahoo.
brian wilson
80 cj5 "high 5"
stretched to 100" wb
351w/np435/d300/d44/d60/detroits/4.56/35ss/bdlocks
