Which tubing bender and Notcher?? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-15-2000, 12:14 PM
Well, I am about to spring for a tubing bender and notcher. Any suggestions? Do I need hydraulic or can I be happy with a non-hydraulic bender? Any experience with the hole saw Notcher versus the other type that appears to just cut? Thanks
Bakes
83 Scrambler
90 Bronco
post #2 of (permalink) Old 09-15-2000, 12:48 PM
Re: Which tubing bender and Notcher??
Try this site for a bender. I looked at the features because it will allow you to make a continuous arc without repositioning the tubing. http://www.mcinnisindustries.com/bender.html
1974 CJ5 304
1989 Cherokee 4.0
The day after tomorrow is the third day of the rest of your life !!
post #3 of (permalink) Old 09-15-2000, 01:29 PM
Here is some more ideas:
http://www.americanbending.qpg.com/
http://www.kartworld.com/tubebender.html
http://www.northerntool.com/cgi-bin/...5&prmenbr=6970
http://www.northerntool.com/cgi-bin/...6&prmenbr=6970
http://www.northerntool.com/cgi-bin/...8&prmenbr=6970
another bender is Hosfeld (?) Good luck, Carl
1974 CJ5 304
1989 Cherokee 4.0
post #4 of (permalink) Old 09-15-2000, 02:03 PM
be careful what you buy.... there are three types.
1. parts bender. Allows you to bend flat stock and bar.
2. pipe bender. bends pipe NOT tubing (ie not what you
would use to make a roll bar.
3. tubing bender. bends seamless, and electrically welded
structural tubing.
4. The difference between the tubing bender and the pipe
bender is the negative arch on the inside of the dies.
Hope that helps....
Tom
post #5 of (permalink) Old 09-16-2000, 03:16 AM
I have a JD2 (J-D squared) model 3 bender, it works very well and the price was very reasonable. It is not hydralic and while it would be very nice, I can't see spending $1000 to convert it. Manual is kind of a pain but if you got a buddy to reset it while you move the bar it's not too bad. There was another guy locally that was using the model 3 with the hydralic kit and last time I spoke to him he was looking to upgrade. I'd like to upgrade as well but can't afford to. I guess what bender depends on what you plan to do. I use my for my own personal vehichles, friend's vehichles, and occasional jobs for strangers. If I used it everyday I would defiantely upgrade. If your just planning to use the bender for you and your buddies I think a manual bender would be fine. However if you're going to use it as a business, upgrade to a nicer production style bender. Also definatly get the tightest radius, 180 degree dies. As for the notcher I got the 'ol joint jigger from Northren equiptment. It's a nice notcher but it's key selling point for me is that it is one of the only nothers that goes to 60 degrees, most quit at 45. When I first got it I tried using it in the drill press and I guess I bent the shaft a little. Now I use a 1/2" air drill and it works a lot better. I'm still fairly new to the fabricating biz but the best advice I can give is to buy all your brackets and tabs premade. Unless you have a punch and flametracer a lot of your time will be wasted making little tabs instead of bending and welding. I use a lot of tabs for Chassis-shop as well as a few others. There's plenty of money to be made if you plan on doing fab work as a side business. Matter of fact I'm flying to Dallas next week to take a look at a truck I'll be doing some work on, and I'm just a little guy working out of a friends garage. I could quit my night job and do this full time already but I'm spoiled by my steady paycheck and benefits. Best of luck
Travis
www.jd2.com
www.ChassisShop.com
www.NorthernTool.com
So many Jeeps... So little time[img]/wwwthreads_images/icons/crazy.gif[/img]
post #6 of (permalink) Old 09-16-2000, 07:48 AM
jeepfreak1
Here are some other links to check out.
http://www.lowbucktools.com/
http://www.vansantent.com/
http://www.pro-tools.com/
http://www.jd2.com/
<font color=green> JF1 </font color=green>
