stupid question-drum removal - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-13-2000, 08:26 AM Thread Starter
I am trying to remove the drums on my amc 20 axle. Do I have to remove the big a$$ nut that holds the axles in place to get the drum off or should the drum come off after removal of the screws and backing off the brake adjuster?
opinions/advice appreciated
CJay
CJay is offline
post #2 of (permalink) Old 09-13-2000, 08:36 AM
Re: stupid question-drum removal
the drum should come off.drums can be a real pain in the a$$ as i see you have found. go to the back side of your backing plate and turn the adjuster like you were adjusting them down. the more you loosen the shoes will draw away from the drum and allow the drum to come off. it still may need alittle persuation with a hammer. oh just in case you don't know where the adjuster is, it is a oblong slot at the bottom of the backing plate. there should be a little rubber plug that goes in it so you'll have to remove that. then look inside the slot and you will see a ring with teeth on it and that is what you turn. just use a screw driver. i can't remember which way to turn it but i am pretty sure you rotate it down. hope this helps.
brian wilson
80 cj5 "high 5"
stretched to 100" wb
351w/np435/d300/d44/d60/detroits/4.56/35ss/bdlocks
post #3 of (permalink) Old 09-13-2000, 08:49 AM
elusive's Avatar
yup yup yup.... just dont hit the drum too hard with a hammer.. i broke a couple wailing away on them..use a dead blow
~~Elusive~~
tj-7..tellico tested, uwharrie safaried, [img]/wwwthreads_images/icons/tongue.gif[/img]..see it at http://www.jeepgod.net
oh yeah, and a 2000 tj, 4.0, dana 44, nv3550
elusive is offline
post #4 of (permalink) Old 09-13-2000, 12:42 PM
jeepgod's Avatar
some might have 3 screws in them.. cant remember.. take them out.. and do what high5 said.. and tap it with a hammer.. if you chip it alittle.. its still ok.. as long as it doesnt go so far to where the pads ride.. or crack it.. those are bad..
jeepgod is offline
