Re: T-18 Questions
the inline 6 models had NO adapteron the front, they bolt directly to the bellhousing, all T18s in Jeeps before 1980 had a 1 inch adapter to the dana20/dana18 older versions
the 81-82 J truck T18, actually is pretty desirable. here is why:
the rear adapter is about 5 inches long, itll bolt to a Dana300
so you can remove the FRONT 5 inch adapter, install the Short Ford input shaft and bolt it into a Cj7 or 8 ( still too long for a CJ5) and itll fit just like hte T18 you are running right now Jeepgod! but im suprised you say it fits, most folks consider the resulting rear driveshaft too short
the bad part, hard as heck to find!
OzarkJeep
"Too small to be seen, and too big to control, and treated like a walking bomb."
