TF727 Flexplate - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-12-2000, 03:01 PM
TF727 Flexplate
Last year i swapped my 258 for a 360 and bolted it to my TF999. At the time i bought a new flexpate for the conversion. Now my TF999 is starting to slip and i plan to replace it with TF727. Can i use the same flexplate? I believe i read that the TF use the same flexplate when bolting to the 360 and the TH400 uses a different one. Thank You in advance
post #2 of (permalink) Old 09-12-2000, 04:16 PM
elusive's Avatar
Re: TF727 Flexplate
yes it will fit.. but....you did order the 360 flexplate right?? because the 258 one is neutral balanced. if you ever get your 360 balanced, use one from a 258. some of the later 727's used a funky reduction starter. my 88 didn't.
but if your only asking if the bolt pattern in the crank is the same.. yes it is.
~~Elusive~~
tj-7..tellico tested, uwharrie safaried, [img]/wwwthreads_images/icons/tongue.gif[/img]..see it at http://www.jeepgod.net
oh yeah, and a 2000 tj, 4.0, dana 44, nv3550
elusive is offline
post #3 of (permalink) Old 09-13-2000, 09:49 PM
Re: TF727 Flexplate
Howdy stranger,
The tf727 torque converters came with two bolt patterns. It's been a while but i think the smaller (high stall) converter had the same bolt pattern as the 904/999. Look around and see if you can snag the one from the donor rig.
CJeep
mopar4ever is offline
post #4 of (permalink) Old 09-14-2000, 05:42 AM
elusive's Avatar
Re: TF727 Flexplate
the flexplate i bought fo mine had both bolt patterns drilled in allready
~~Elusive~~
elusive is offline
