welded in-frame nut un-welded - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-12-2000, 08:23 AM
I'm sure we've all experienced this one.
In looking to replace the factory front shackle hangers, one of the nuts (rear shackle hanger/steering box) inside the frame has un-welded, so I can't get the bolt out. Any suggestions?
Thanks again,
canis
canis
Who needs a road...if there's a perfectly good JEEP trail somewhere else!?
post #2 of (permalink) Old 09-12-2000, 09:03 AM
Re: welded in-frame nut un-welded
I have replaced them by taking off the front bumper and punching the old nut assembly out. Then put a grade 8
bolt in the hole and put it back together. If you don't want the bolt to turn when you put the nut on you can weld it in there or weld something to the head of the bolt to cause interferance so the head doesn't turn.
post #3 of (permalink) Old 09-12-2000, 09:13 AM
I personnaly havent tried this,but I think it would work.Drill a small hole right beside the bolt and either stick smaller bolt in the hole or weld it.That should keep the nut from turning.The heat from a weld would loosen the grip on the bolt also.
post #4 of (permalink) Old 09-12-2000, 10:21 AM
I Do This For The Glory
JEEPN's Avatar
Yep, this is common. I torched out a small section of the frame so I can get a wrench in there and get at the nut.
JEEPN
'81 CJ-8 Scrambled!
GM151/SM465/NP205 twinstick/7" Lift/33" Swampers/REP 8000/RS9000's/Scout II D44's F&R w/4.10's & Lockrights
JEEPN is offline
post #5 of (permalink) Old 09-12-2000, 04:32 PM
I punched out the captive nut, drilled the hole thru the top frame rail also, then got 4.5 inch ( think 4.5 inch0) grade 8 bolts down thru the top to stick out the bottom like studs. put some sleexes (small pipe from lowes) inside so the frame doesnt compress
weld the tops ( carefully isolate the heat so you dont soften them too much!)
hold hte tops with a wrecnh when you tighten the down so you can really load em up good without breaking the welds
I did this to the entire front driverside on mine ( steering box mounts) some previous owner jerky welded the box brackets to the frame -crossmember-bolts were all wedled on, it was a real work of "ART"
OzarkJeep
"Too small to be seen, and too big to control, and treated like a walking bomb."
ozarkjeep is offline
post #6 of (permalink) Old 09-12-2000, 05:31 PM
I had this same thing happen to my 1981 CJ-5. I pulled the front bumper off and got to the nut with a box end wrench. Used grade 8 nut/bolt to finnish the job. You could cut the bolts off and drill out the hole and finnish the same way.
Good Luck!
Kriss
