Help! Broke a Stud on a 4.2 Exhaust Manifold - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-11-2000, 12:28 PM Thread Starter
Last night my wife told me FrankenJeep was too loud. I figured that I would tighten up the header pipe to ehaust manifold joint to fix a small leak on the 258. As things normally go, the stud snapped off VERY easily. My question is, how do I get the remains of the stud out? Do I remove the manifolds & polution stuff or should I try to remove the engine mount to drill it out on the Jeep?
The stud snapped off flush with the flange and this is an 80 CJ with the intake & exhaust manifolds bolted together.
If I take them off, should I put the polution plumbing back on? It just past E-check here in Ohio with the following emmissions: HC 19.1PPM out of 174.0 allowable, CO 1.12% out of 2.19% allowable and CO2 at 11.80% This is with a Weber carb and TeamRush ignition.
Thanks in advance.
Karl
80 CJ/YJ-7 FrankenJeep
Swede is offline
post #2 of (permalink) Old 09-11-2000, 12:50 PM
Re: Help! Broke a Stud on a 4.2 Exhaust Manifold
[img]/wwwthreads_images/icons/smile.gif[/img] An ACE welder could weld a nut onto the broken-off-flush stud from the bottom. You hold the slightly-oversized nut in place with the welder ground clamp from above and Ace gets below with TOTAL LEATHERS and welds the crap out of it. THEN, you guys go do something else for several hours while the stud shrinks back FARTHER THAN IT WAS, and then you carefully twist back and forth till you get a full revolution, and then turn it on outa there.[img]/wwwthreads_images/icons/smile.gif[/img] The key word here is ACE. This is not for the faint of heart nor for the novice, but it works every time and saves taking a lot of stuff off unnecessarily.[img]/wwwthreads_images/icons/crazy.gif[/img] If you were close by, I would have that out of there for you in exchange for a shockingly cold Coca-Cola in the glass bottle.[img]/wwwthreads_images/icons/wink.gif[/img]
CJDave
CJDave is offline
post #3 of (permalink) Old 09-11-2000, 08:46 PM
bummer been to this movie.......didnt like the way it ended.........dont know where you are in ohio but i am in dayton area and took my manifold to numbers machine shop in englewood and they drilled it out and retapped it for next to nothing.......sorry bout your luck cause i have same luck......
'78 cj-5 not perfect......but fun
