Adhesive suitable for welding? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-11-2000, 11:25 AM Thread Starter
I'm wondering if there's some sort of adhesive like JB Weld or somesuch that is suitable for using on parts that are to be welded. I've got all of my misc. mounts & brackets that Framjeep is going to weld onto my frame for me and I'd like to position them prior to his arrival so that he can just start laying beads instead of me getting in the way to measure, grind, etc. The main issue is that another Jeeper fabbed up some really nice replacement body mount brackets for me, so obviously placement of these is pretty critical and needs to be based upon the location of the original mounts. TIA
Jeepskate is offline
post #2 of (permalink) Old 09-11-2000, 11:46 AM
Matt M38A1
Re: Adhesive suitable for welding?
Those big C-clamp looking Vise grips work great for that. Or even cheap c-clamps will do, and you won't have a mess of stuff everywhere.
post #3 of (permalink) Old 09-11-2000, 11:54 AM
my understanding is that it wouldn't work with the JB weld. I have only used it a few times but its not steel so it wouldn't be a good idea to try to weld on top of it. I would think that make more of a mess than its worth. Unless you just put a little hear and there to hold the body mount and weld around the JB weld. Than grind the JB weld off before finishing the weld.
Honestly, I can hardly believe that I am trying to answer "JeepSkates" question. I have been watching your project since 1997 (when I bought my TJ) and think you and some other guys are amazing with the things you guys come up with. Good luck on your project.
1997 TJ w/ 33's
1984 CJ7 V8 SOA w/35's or 39's
http://members.aol.com/a4x4jeeper/
OverMost 4wd Club President
www.jeepeast.com/overmost
post #4 of (permalink) Old 09-11-2000, 12:14 PM
I Do This For The Glory
JEEPN's Avatar
A clamp would work best. I have heard of people using solder and/or brazing rod to do the same thing. Solder is nice because as you weld, it melts away and you can continue welding. It'd just be a PITA to get it to adhere with that much mass. How about normal C-clamps? Even better, clamp it in place and mark it up well, then just align the reference marks.
JEEPN
'81 CJ-8 Scrambled!
GM151/SM465/NP205 twinstick/7" Lift/33" Swampers/REP 8000/RS9000's/Scout II D44's F&R w/4.10's & Lockrights
JEEPN is offline
post #5 of (permalink) Old 09-11-2000, 12:37 PM
[img]/wwwthreads_images/icons/smile.gif[/img] How about using a small drill and some spring pins for "locating"? If you got one pin in there, then the rest would be just a matter of twisting the piece to get it "normal" for Dean to weld it.[img]/wwwthreads_images/icons/smile.gif[/img] OR....you can even match-mark the stuff to the frame with a center pinch or a scratch awl.[img]/wwwthreads_images/icons/crazy.gif[/img] We used to have this incredibly powerful magnet that i sometimes used to put behind a frame member to hold a bracket in place on the outside. The problem with that was that the magnet picked up every piece of grinder shavings or cuttings within ten feet and it was tough to get it off.[img]/wwwthreads_images/icons/crazy.gif[/img]
CJDave
CJDave is offline
post #6 of (permalink) Old 09-11-2000, 12:38 PM Thread Starter
Thanks, JW. I'm still learning things just like everyone else...there's always some new twist or something I haven't stuck my hands into yet. That's part of what keeps this whole thing interesting.
post #7 of (permalink) Old 09-11-2000, 12:42 PM Thread Starter
I guess I'll stop at Menard's on the way home (good local chain for cheap stuff) and compare prices between c-clamps and the spring-loaded clamps (can probably find those in a bulk pack). Probably need at least 10 of them...should be enough material on the flanges for the clamps to catch on. Thanks.
post #8 of (permalink) Old 09-11-2000, 12:43 PM Thread Starter
Thanks. I've got a couple of c-clamps and one of those vise-grip clamps. Guess I'll compare the prices on c-clamps verses spring-loaded clamps and go with the cheaper of the two. Thanks.
post #9 of (permalink) Old 09-11-2000, 01:18 PM
I like CJDave idea, also consider drilling small hole and using small selftapping screws. you can weld up the scews when you weld the pieces on. Just make sure you drill your holes in nuetral areas of the frame, etc.
Enjoying Montana's Big Sky (NOT, Fire Fire Everywhere)
jfralph is offline
post #10 of (permalink) Old 09-11-2000, 02:28 PM
If you use a magnet you can stick it in a zip-lock baggy. Then when you remove it you just turn the baggy inside out and wala- all the shavings are in the bag.
Restoring a '74 DJ-5C [img]/wwwthreads_images/icons/cool.gif[/img] It runs [img]/wwwthreads_images/icons/smile.gif[/img] and drives [img]/wwwthreads_images/icons/shocked.gif[/img] and delivers mail...well, 2 out of 3 aint bad [img]/wwwthreads_images/icons/wink.gif[/img]
Sycho15 is offline
